This likely has a diode module which rectifies a low voltage AC winding to do the charging.
Things to check: There USUALLY is a fuse on the low voltage winding. It SOMETIMES is within the generator covering.
Check for loose connections or broken wires.
The diode module is usually a 25 amp block about 1.25 inches square with 4 faston terminal connections.
Use a meter set to AC to check voltage on the AC terminals... might be around 18 volts or so.
Then on the DC terminals labeled + and - with meter set to DC.
To charge a 12 volt battery there needs to be about 13.75 volts or so.
