The trimmer/switch is broken. You will need to replace it. You will find the components that you require at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8995-8595-and-8795-body-housing-with-trimmer-p-684.html
To replace the part you will need to remove the 'cap' that surrounds the cord hole on the bottom of the shaver by gently prying it off with a small flat screwdriver or similar object. Once removed, the side grips will easily pull off revealing 4 screws. Remove screws to seperate the front and back case. The inner parts simply lift out and you can put them into the new case
