Photography Logo
Posted on Mar 20, 2010
I don't know what is wrong with my old camera!
Hi! About two or three years ago, my dad gave me his old Canon Sure Shot Autofocus 38mm film camera. I got the right film for it, and my brother tried to put the film in, and it took him a couple tries to figure how to load the film(resulting in a wasted two rolls of film,lol). Well, it worked fine for about ten pictures, and then it wouldn't take anymore pictures. I was 12 at the time, and so I started messing around with it, and the batteries weren't dead, and I opened the back of the camera to see if something was up with the film, but I didn't see anything wrong(but I think I exposed the rest of the film!). So I finally put it away, and I was cleaning out my junk drawer and found it again. I put some new batteries in it to see if what I think is the "on" light would come on, and it didn't. Sooo,long story short, could you maybe walk me through on what to do to find out what is wrong with this camera? Thank you so much!
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Sep 21, 2007
SOURCE: Canon T70 35 MM SLR Camera
It sounds like your camera is having problems advancing your film, which could mean it is jammed inside the camera. The other thing you should check is to see if the battery is weak & doesn't have enough power to advance the film (and thus the beeping). If it is not the battery, then go in a darkroom (completely dark) and take out the film (if you're unable to rewind it inside the camera). Look at the transport rollers (in the back for the camera) and make sure they're clean (sometimes film chips get jammed in there) Let me know if this helps you. Thanks.
Anonymous
  • 14 Answers
  • Posted on Jun 29, 2008
SOURCE: LOADING FILM INTO MY CAMERA
Camera will not fire with dead battery so you will not be able to advance film to #1.......ck out www.flcamerarepair.com for help
Anonymous
  • Posted on Jul 23, 2008
SOURCE: Film will not load
Took out the battery, then put it back in. The film then loaded properly.
Anonymous
  • 423 Answers
  • Posted on Mar 16, 2009
SOURCE: Nikon EM (1979?) Won't wind film, photos don't come out
Not necessarily. The EM has an M90 setting which will fire the shutter at 1/90th of a second. The meter is inactive on this setting. It was put on the EM so that if the batteries fail, you can shoot at 1/90th and take a guess at the exposure. There is also a small button (blue or chrome, depending on the production run) which lights up a red LED if the batteries are good. The light meter doesn't work until the frame counter is at 1 or higher. Before the #1, the shutter will always fire at 1/2000th of a second to speed up the film loading process. You can tell that the meter is working by observing the meter's scale/needle on the inside of the viewfinder. If it is pointing out of the red zone, it's OK to shoot (proper exposure). If the needle is in the red zone (indicating under or over exposure) the camera will "beep" as an audible warning. Check the battery condition first.
pontelemon
pontelemon
  • 538 Answers
  • Posted on Apr 02, 2009
SOURCE: new film will not load or advance in my Canon rebelx 35mm
Gears are broken in Advance Assembly.
Top Canon Photography Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Canon Photography Expert? Answer questions, earn points and help others
