Paxar Monarch 9825 Thermal Label Printer Logo
Posted on Mar 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 768 - Paxar Monarch 9825 Thermal Label Printer
A Miller
Level 3:
  • Master 8,404 Answers
  • Posted on Mar 09, 2010
A Miller
Master
Level 3:
Answers
8404
Questions
Helped
2091790
Points
24679
Do you have the operators manual?
I found the manual and looked at the error codes. 768 is 30 or more dots that arent working. Here is the link: http://www.sourceithere.com/catalog/images/9825qr.pdf
What is this error 524
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Error codes and LED blinking codes to many popular brand tVs are given.
1helpful
Sony Bravia KDL 32BX300 Error codes
Five blinks denotes an IRK error. To detect damaged components and to troubleshoot this error, you must have sound in electronics.
6helpful
2answers
Printhead error #768
The print head problem occurs if the drain tubes being clogged and is preventing the pump from sucking the ink out of the print-head. It could also happens if the ink lines allowing air into it.
There are few troubleshooting steps in trying to fix this issue. Click here for a detailed checkup.
Check print head #768
This is the error code stating that there are more than 8 print elements faulty and requires replacement.
However if the cabel to printhead is not installed correctly this can also give the same error - check it is fully connected.
Printhead Error #768
That's a printhead failure error code. The printhead needs to be replaced.
Problem with hpl1506 lcd
if your pc display resolution is set to 1024 x 768 and still having this problem... then your LCD control board is faulty. WHat you can do is try to hook up your pc to another monitor and try other resolution setting. If you still get the same error...then you will need to get someone to repair ur LCD...
Top Paxar Office Equipment & Supplies Experts
Paul Bade
Martin C
Are you a Paxar Office Equipment and Supply Expert? Answer questions, earn points and help others
