IBM ThinkPad T42 Notebook Logo
Posted on Mar 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bluetooth how to activate bluetooth in ibm t42 ?
Anonymous
Level 2:
New Friend:
  • Expert 72 Answers
  • Posted on Mar 09, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
72
Questions
0
Helped
13283
Points
212
Search for the antenna logo on the Thinkpad hit it and activate bluetooth and i think that your laptop does not include bluetooth
4 Related Answers
Anonymous
  • Posted on Dec 25, 2010
SOURCE: ibm thinkpad t42 switch for wireless network
How do I get my wireless network on in my IBM T 42
Anonymous
  • 250 Answers
  • Posted on Jun 08, 2010
SOURCE: IBM T42
Hi, This is a motherboard issue, this is a know issue on T42 you should contact Lenovo support to get a planar replacement. Thanks and have a nice day J-
Anonymous
  • 393 Answers
  • Posted on Sep 15, 2010
SOURCE: ibm t42 thinkpad t of svp password
For IBM/Lenovo Password
there is solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. u need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..u need to make com port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html
Thanks
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Nov 24, 2011
SOURCE: my touchpad buttons don't work IBM T42 laptop
In this case you probably disabled it by mistake ..and you need to enable it again ..Go to control panel ..and locate the touch pad..and see if it needs enabling . If this will not work ..you have to download the driver for the touch pad..and reinstall it ..or ..if the driver is still in the system it is enough to get to control panel ..add hardware ..and run the add new hardware wizard..This will search for hardware and show the ones which are not installed or ..if no one is present ..select already added and look for the pad..
Or ..I would option for getting into device manager..(right click on computer ..select properties../hardware /device manager..or direct device manager for win7 ..)
in the device manager select the touch pad..and click right on it ..and select update driver..This will start the wizard and install the missing driver if it is still in the system ..If it isn't you will have to install it manually after you download it from the support site ..or from the disk .
Need LAN driver for IBM thinkpad T42 cruz_369@yahoo.com
IBM ThinkPad T42 LAN Drivers
Please visit the above link from Official IBM Support and download the required Drivers
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
I coudn't found my wirless swich of my ibm thinkpad t42 laptop
There is no hardware switch wireless. Just hold Fn and press F5. It would brings up a menu that allows you to turn Bluetooth on/off, WiFi on/off or both.
Hope this helps
3helpful
2answers
My wireless was working on my T42 IBM last week. It is not working now. The only thing that happened in between is that I installed Microsoft Office. How can I get my wireless back? I get a message that I...
For most IBM ThinkPads, the shortcut key to activate wireless is Fn+F5. I am not so sure about this model, but you can try. If this doesn't help, check the Device Manager and make sure it's shown on the devices lists. By default wireless is activated once the driver is installed on almost all IBM ThinkPads. You problem could be driver corrupted or missing. The best resolution is reinstalling the driver so that it'll not fail. If the problem persists, then it could also be your wireless card failure. You better check it twice.
Good luck.
Thanks for using FixYa.
IBM T42
Trying to connect bluetooth on laptop to phone blackberry curve 8330m
does the pc have have bluetooth or just capable? bolth bluetooth deviecs must be in receiving mode. download a bluetooth serial finder application matching your operating system. if that does not find the phone when in its in receiving mode u need to ensure pc has bluetooth card enabled w proper drivers!!!
2answers
Where is the wireless switch for ibm t42 laptop i have tried fn and f5 nothing works
There will either be a switch on the side of the machine or it will be fn and one of the funtion keys, look for an image like this:
http://hpshopping.speedera.net/www.shopping.hp.com/shopping/images/overview/wireless_black.jpg
After reinstalling XP on T42 I can't turn on the wireless network
Check that the correct device driver is installed using the device manager via the control panel.
Download driver max to automatically check all your drivers for free.
23helpful
2answers
Where is the wireless button on t42 thinkpad
There's no hardware switch to activate and deactivate the wireless networking, but pressing Fn and F5 brings up a menu that allows you to turn Bluetooth on/off, WiFi on/off or both. It seems like IBM isn't satisfied with standard toggle buttons like other notebook manufacturers - even pressing the Fn and F7 buttons to switch between internal and external screens, brings up a menu with multiple display settings and resolutions.
Hope this helps,
David
Top IBM Computers & Internet Experts
Frank Fernandez
Sudeep Chatterjee
Sudeep Chatterjee
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
