Borrow another display from your friends, or get an used one from someone who has extra display, and recycle your old one with your local recycling business.
Those are not simple problems. From your description, you probably gonna need to replace both the screen/flat cable and the keyboard (these parts just can't be repaired, must be replaced).
Format your mobile with ufs. If the problem exist there, then flash it If it again shows the problem then go to a mobile repairing shop because its lcd or display ic may be found faulty.
good affter noon I am tecnecion my name is firoj ahmed from nepal I have a problam. this photo copy display on but not works.this masses a call servic centar on screen so I want to solve this problam ok
Please check the display in BIOS. To go to BIOS , restart your system and start tapping the F2 key. This will take you to BIOS. If you still see bad display in BIOS, you may need to get the LCD replaced.
Make sure that the monitor is turned on and has power. Make sure
that the display's power cord is plugged into a working wall outlet,
and that it's properly connected to the power adapter. (To check if the
wall socket is working, plug in a lamp or other electrical device.)
Check that all video cable connections to the computer video port and to the monitor are properly connected.
Examine the pins on the video cable connector to make sure they are not bent or damaged in any way.
Connect a known working display (if you have an extra one available). If you see video after doing so, replace your old display.
Unplug the video cable and then turn on the monitor, check any message is showing in monitor if its shown means ur monitor is ok or else their is a problem in monitor..
