Sometimes my dehumifier (Goldstar) leaks. It is not full and the collecting bucket is fitted properly. I see that there is a flap around the pipe coming from the coils. Is it possible that this flap is...
Gary, most of the time, what you described is caused by 2 thing:
1. The cooling coils are icing up and not thawing as they should. This is usually caused by a dirty or clogged air intake filter. Solution: Turn the unit OFF, unplug it and remove and clean the air intake filter.
2. The drain hole or tubing, that drains water into the bucket is clogged. Solution: Using an 18" long plastic Zip Tie or something similar that is flexible (NO wire coat hangers, though) and appropriately sized to fit into the hole or tubing. Carefully insert the Zip Tie and continue to push it in, until to reach the bend in the tubing. You must gingerly work it past this bend, until it either bottoms out or you run out of usable Zip Tie. While slowly pulling it out, rotate (twist) the Zip Tie and as it reaches it's end, be prepared for some water to follow. That procedure will loosen any clogs.
Hope this helped you troubleshoot and solve the problem. Please let e know. Thanks.
we have a goldstar dehumifier, and it is leaking/draining onto the floor not into the fill bucket
My dehumidifier is running constantly, but the water goes onto the floor and not into the well. I cleaned the filter, and it collected water once, but is once again going on the floor.
