F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.
Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board. The parts can be ordered from
Sears PartsDirectNOTE: Disconnect the power supply from the oven before servicing.
Check additional details in
THIS IMAGE LINK.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
Thank you for using Fixya, and have a nice day.
