Computers & Internet Logo
Posted on Feb 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Distorted display - Computers & Internet
Anonymous
Level 2:
Sergeant:
  • Expert 244 Answers
  • Posted on Feb 16, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
244
Questions
0
Helped
55323
Points
595
You could isolate the problem if it is a monitor / video card problem by removing the cable (VGA/DVI) and see if the self test feature will have a distorted display
If Yes - Monitor Problem
If No - Video Card Problem or Software problem
If no, try to go to safe mode by tapping "F8" once you turn the computer on.
1. Select Safe mode (Check for video distortion)
2. Select Enable VGA Mode (Check for video distortion)
If one of the 2 is distorted the video card has a problem
If one of them doesn't show any distorted video it means its a driver/software problem.
Hope this helps.
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
tip
Wide screen monitor distortion Depending upon the screen resolution that has...
Depending upon the screen resolution that has been set in Display, the image will be distorted on these large wide screen monitors.
To correct this distortion.
1. Create a large circle image using a draw program such as Paint (hold down the Shift key as you create the circle as it will draw a perfect circle).
2. Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle.
3. When you are satisfied then click apply.
on Feb 24, 2011 • Computers & Internet
How to degausse gpsmap 172 gps
Hi Donnie,
Degaussing is not something that ever needs to be done on this device.
Degaussing is a term that I learned many years ago - it was a process performed periodically on early CRT (cathode ray tube) displays (such as a TV). Over time, CRT displays would build up magnetic charges that would cause the image to become distorted. A degaussing wand would be connected to an AC outlet and then brought very close to the display and gradually withdrawn. This would neutralize the magnetic charges on the display - and the resulting distortion. Years later, manufacturers incorporated a degaussing coil inside the display's cabinet that did the same job as the degaussing wand - thereby making the wand obsolete.
The GPSMap 172 has an LCD display that requires an electrical charge to create an image on the display. Unlike a traditional CRT type displays, an LCD (or LED for that matter) display is unaffected by magnets / magentism. Hold a magnet near a non-CRT type display to see for yourself. A magnet held near a CRT display however will distort the image more as it gets closer to the display. Caution: Doing this may cause PERMANENT damage to the CRT display. This is why many home theater speaker systems touted that fact that they were "magnetically shielded" so that they would not distort the images on the CRT display.
I hope this helps!
There are these lines of static, distortions across my screen that only visible in certain situations. For instance, as I am tying this the bottom of the words 'static, distortion' are distorted (looks...
Go into control panel, properties, advanced, monitor, refresh rate and select display refresh rates that my monitor can display and then choose which one best suites you and your problem.
1helpful
Distorted display/aspect HP w1907
This is a common problem with wide screen format.
The way I overcome this distortion is to open a drawing program and draw a circle, some programs require you to hold down the shift key to produce a perfect circle.
I then go to the Display Settings and adjust the screen resolution to get the best display that fills the screen and that gives me the perfect circle.
If this does not work you may need to download the latest video driver for your graphics card and then adjust the screen resolution..
Laptop Screen distorted.
Your LCD ribbon cable that connects the panel to the motherboard might be damaged. I recommmend calling HP to get it serviced, or go to your local computer repair shop and have look at it. Hope this helps!
1helpful
Display distorted
Install Proper Driver for VGA
Download and install from www.dell.co.in
8helpful
Distorted color on hdmi output
If you haven't already stumbled across the fix: I just had the exact same problem after about eights months of casual use. Unplugging the DVD player for about 15 minutes and then plugging it back in "solved" the problem. Until next time it happens, anyway.
My acer aspire 4530 has always be given a distorted display can someone help me resolve this problem?
For, distorted display problem there are 2 possibilities
1> your display drivers are not installed properly so try to remove or uninstall driver from device manager and add & remove program and than install proper drivers
2> if the distorted display is from boot screen than its definately a RAM problem so kindly remove it and refit it properly and if still problem continues than kindly replace it.
Hi,i have a whistler 1773 laser-radar detector and it reads on the display DISTORT.i can't find anything in the owner's manual or on the website.can you help?thanks, angie
If compass is not calibrated correctly or if there is a strong magnetic field (dash or windshield mounted speakers), the unit will show incorrect direction or display "DISTORT". Re-calibrate the compass to correct the readings. Units that display "DISTORT" need to be moved farther away from the speakers or other magnetic field, then re-calibrate the compass. Optional Theft Protection/Extended Warranty Theft Protection
Whistler's optional 3 year theft warranty program (effective January 2002) offers the detector user protection against theft of their laser/radar detector. In the unfortunate event that your detector is stolen, it is comforting to know that your detector will be replaced! Simply follow the directions on the form enclosed with your unit or print out our online form and mail it, along with a copy of the receipt and payment, to the address listed. Once the form and payment is received we will provide you with a reference number. Note: The theft warranty protection isn't in effect until you receive a reference number from us. Our current program requires that the form and payment must be returned within 30 days of purchase, however and for a limited time only, we are waiving the 30 days from purchase requirement. If you have purchased any 1600 series laser/radar detector (This special offer is not available on any other detector model.) you are not too late, simply follow the instructions on the form and mail it in to us. In the unlikely event that your detector was stolen, simply inform us within 30 days of the theft and provide the following information:
  • Your theft protection reference number (Issued upon receipt of payment)
  • Name
  • Current complete address
  • Daytime telephone number
  • Email address (if applicable)
  • A copy of the police report indicating that your Whistler detector was stolen.
Once the above requirements are met a replacement or equivalent unit will be sent to you within 15 business days.
This offer is made available only to the original purchaser of the detector and is non transferable. Once used, this warranty is cancelled and a new one must be purchased for coverage of the replacement unit.
This offer is available in the U.S.A. only. Theft applications or claims from outside the U.S.A. will not be accepted and a copy of the original store receipt MUST accompany this form!
Extended Warranty
We are pleased to offer you an extended warranty for your Whistler laser/radar detector. Under the extended warranty, your detector will be warranted to the original purchaser for a period of 1 year from the date of expiration of the original warranty against all defects in materials and workmanship. To purchase the extended warranty, simply follow the directions on the form enclosed with your unit or print out our online form and mail it to the appropriate address provided, along with a copy of your sales receipt and a money order for $20.00, or payment can be made by Visa, MasterCard, American Express. (No personal checks will be accepted). You must receive a reference number (issued upon receipt of payment) from Whistler in order for your warranty to be in effect. This limited warranty is void if the unit is abused, modified, installed improperly, if the housing has been removed, or if the serial # is missing. There are no express warranties covering this product other than those set forth in this warranty. Whistler is not liable for damages arising from the use, misuse, or operation of this product. When returning a unit for service under warranty, please follow these instructions: Ship the unit in the original carton or in a suitable sturdy equivalent, fully insured, with return receipt requested, and shipping charges prepaid to:
The Whistler Group
Customer Repair Center
1201 N Dixieland Rd
Rogers, AR 72756
Include with your unit the following information, clearly printed:
  • Your name, street address, daytime telephone number and (if applicable) an email address.
  • A detailed description of the problem.
  • A copy of the sales receipt and extended warranty reference number.
To validate that your unit is within the warranty period, make sure you keep a copy of the original store receipt and the extended warranty reference number issued by Whistler. IMPORTANT: Whistler will not assume responsibility for loss or damage incurred in shipping. Therefore, please ship your unit insured with return receipt requested. -->
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
