Stoves 12 in. (1248-1100) Electric Cooktop Logo
Anonymous Posted on Feb 19, 2010
Have been asking the same question now and giving additional info including the make and model #. am not getting ANY answers. are you helping or not
Bob Korsu
Level 3:
Guru:
  • Master 1,051 Answers
  • Posted on Feb 19, 2010
Bob Korsu
Master
Level 3:
Guru:
Answers
1051
Questions
0
Helped
409837
Points
3047
I never saw your original question? I may be able to help if you can repost.
2answers
Can we fix this ?
im sorry but no one can answer your question as we do not know what you need fixing ? please give more info as to what the problem is and then people can help ...thanx
Apr 21, 2015 • Cooktops
How do I replace a gas hob ignitor
There are a lot of cook tops out there but we cannot guess which one you have. Give more info such as make and model so somebody can help you.
Nov 25, 2014 • Cooktops
I too am looking for part for my Thermador oven. Apparently 486945 is no longer available and a substitution part 622568 is also difficult to find. I never would have spent this kind of money on an...
I really need to have a bit more information so I can give you a best answer. Please give me the model number of your appliance. Thank you, I did find on the net that someone on Ebay does have your part numbers, but did not go there to see if it is new or not.
Burning smell from LG oven
Hi Mike Plante, I read your problem and would be very appreciative if you can share the solution that you eventually found, as my LG unit has experienced this exact problem after the same repairs were made. Please post an additional comment on the website. Thanks, Jeff
Burners will hang and get hoter and hoter. I got a new thermostate and it worked for awhile and is back doing the same thing
i realiazed after getting into program , that you charge for your inof.
I am only looking for free info. If you cannot give free info , do not contact me any more.
Bobby Glover
Dec 21, 2009 • GE Cooktops
2answers
I have two burners that fail to spark when the control knobs for them are turned on. However, they do spark when another burners is activated. It so happens that when one burner is turned on all of the...
Sir,
Definetly there is problem with grounding. Your guessing is correct sir. Check these links.........
Link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Apr 19, 2009 • GE Cooktops
1helpful
Counter top stove burner won't light
Hi, You asked a very generic question but I will try to give you a good answer. If the pilot is good and you can light the burner with a match, (this checks everything else) then the most common problem would be the burner holes in front of the pilot are clogged. When cool, remove the burner and inspect the holes, any debris needs to be removed, a bent paper clip works really well. Compressed air helps as well. If there is a tube to the pilot make sure it is exactly where it belongs and that it is clean. If the match didn't light the burner or the flames is not all blue like the rest, there is something else wrong and you need to get back to us with a make and model to better help you. Make sure the burner gets seated back on the orifice correctly and best of Luck to you!
5answers
Jenn Aire Cook top
try national parts depot
or look for new knobs that matches the fit and change the broken one or all of them.
Jenn air model JED8430bdb
A similar concern on a different model (8230):
To my knowledge, the:
green - ground
white - neutral
black - 120 to ground
red - 120 to ground but between red & black, it should be 240. A Jenn-Air JED8230 requires a 3-wire, 120/240 Volt, 60 Hz Outlet.
Pls consult/confirm with your local electrical utility/codes the availability/applicability of this power/wiring system or reference National Electrical Code, NFPA No. 70
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Top Stoves Cooktops Experts
ADMIN Andrew
ADMIN Andrew
gerbee gomez
Paul Carew
Are you a Stoves Cooktop Expert? Answer questions, earn points and help others
