Hello experts, I need to replace the waste ink tank on my printer. Do you know where it is located? I have a canon pixma mp 130 printer.
I believe that he is reffering to the waste ink tank where the cartriges stop to the right when not being used. There are two small foam pads over there.
I cleaned mine by opening lid and have carriage run to the left, then I reach in with a q-tip and press down repeatly until q-tips are almost clean. You will need a flashlight to see waht you are doing.
Solution: Replace ink tank(s) MP130
Replacing an Ink Tank
When ink is running low, the LCD will display [BLACK INK LOW] or [COLOR INK LOW] warning you to have a new ink tank ready before the ink runs out.
Ink tanks compatible with the machine are as follows:
Black ink tank: BCI-24 Black
Color ink tank: BCI-24 Color
CAUTION: Do not replace ink tanks while the machine is printing or performing another operation.
CAUTION:
* Do not try to manually move or stop the Print Head Holder.
* Do not touch any metal parts.
CAUTION:
* Do not remove the print head from the machine.
* Remove one ink tank at a time.
* Do not touch the transparent film (A), film cable (B), ink absorber (sponge partcanon multifunction printer - sj402026.jpgy metal parts.
IMPORTANT:
a. Discard the empty ink tank according to local laws and regulations for disposal of consumables.
b. Handle ink tanks carefully to avoid staining clothing or the surrounding area.
CAUTION:
* Do not touch the ink port (B).
* Do not shake or drop the ink tank as the ink may leak and stain your clothes or hands.
* Do not attempt to reattach the protective cap ocanon multifunction printer - sj402036.jpgve it.
* Do not place the ink port in contact with any other surface.
IMPORTANT:
a. Set a black ink tank in the right slot of the print head.
b. Set a color ink tank in the left slot of the print head.
CAUTION: Press the center of the Inner Cover until the cover locks into place.
The ink counter is now reset, and replacement of the ink tanks is completed.
NOTES:
a. Pressing [+] does not reset the ink counter. Be sure to press [-] if you replaced the ink tank.
b. If you pressed [+] by mistake, follow the procedure to reset the ink counter. (See Resetting The Ink Counter)
The pictures and text of this article are here:
http://www.usa.canon.com/consumer/contro...
Type in tank, and go to #3.
