Casio FX-260 Calculator Logo
Posted on Jan 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you calculate standard deviation? - Casio FX-260 Calculator
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Mar 06, 2010
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4761499
Points
21601
  1. Calculator must be in SD mode (standard deviation mode) :Press [MODE] [.]
  2. However, if [FIX] or [SCI] appears on display you must press [MODE][9] first.
  3. Data input always starts with [SHIFT][SAC], to clear the registers of old data.
  4. Type a number and press the [DATA] key, it is the [M+] key at the bottom right of keypad.
After you finish entering the data
Press [SHIFT] [9] (sigma n-1) to get sample standard deviation
Press [SHIFT][8] (sigma n] for the population standard deviation
Press [SHIFT] [7] (xbar) for the mean
Press [SHIFT] [6] (n) for the number of data entries
Press [SHIFT] [5] (capital sigma x) for the sum of values
Press [SHIFT] [4] (capital sigma x to y) for the sum of squares of the values
For additional information you might consider taking a look at the calculator manual.
5 Related Answers
Anonymous
  • Posted on Jan 26, 2008
SOURCE: standard deviation
image001.gif Enter the first number, 1.
image001.gif Hit the σ+ (Sigma+) key. ( n=1 will appear in the window)
image001.gif Enter the second number, 1.
image001.gif Hit the σ+ (Sigma+) key. (n=2 will appear in the window)
image001.gif . . . . .
image001.gif Enter the last number, 7.
image001.gif Hit the σ+ (Sigma+) key. (n=7 will appear in the window)
image001.gif Hit 2nd x2 (by hitting the 2nd key you are actually selecting the x-bar written above the key.) This gives you the mean.
image001.gif Hit 2nd sqrt(x). This gives you the sample standard deviation which we will use in class.
image001.gif Make sure you turn your calculator off and on for new data sets.
Anonymous
  • Posted on Oct 20, 2008
SOURCE: Standard Deviation
When I enter some series of data and check the descriptive statistics, every time I come to the standard deviation the calculator shows me Error 1 message.
Anonymous
  • Posted on Nov 19, 2008
Is there a PDF with the Statistical procedures for this product? I bought my Casio FX-115 used (second hand). No instructions. I need help using the Statistical functions for my Stats classes:
Correlation Coefficient
Standard Deviation/Variance
Chi-Square
x-x(bar) summations
HELP!
marionbagget
  • 718 Answers
  • Posted on Apr 18, 2009
SOURCE: finding standard deviation on Ti-30XA calculator
You can get instructions from;
http://www.geocities.com/calculatorhelp/ti30xa.htm
It's straight forward to follow.
k24674
  • 8093 Answers
  • Posted on Sep 14, 2009
SOURCE: HOW DO I CALCULATE STANDARD DEVIATION ON MY TI34II
Here is an exemple taken from your calculator s guide book
f1dd02c.jpg There is no substitute for reading the user guide.
Hope it helps.
Where is s on the ti-30xa calculator
If you mean the standard deviation, there are two shifted keys on the third row marked with a lower-case Greek sigma. sigma_xn is the population standard deviation and sigma_xn-1 is the sample standard deviation.
How do I use the standard deviation function?
2helpful
Does this calculator comes with a standard deviation or population standard deviation button
Yes. The sample standard deviation is 2nd [sigma x n-1] and the population standard deviation is 2nd [sigma x n].
2answers
Is there a formula for standard deviation problems
Of course there are formulas for those calculations. You find them in books on statistics. Do not worry, the calculator has been programmed to use them. All you have to do is learn how to get the calculator to give you the results.
If you still want to see the formulas with your very eyes, I suggest you go to the local library, ask a math teacher, an accountant, or launch a Google search for them.
Hope it helps.
2helpful
Standard Deviation
Press 2ND [CSR] to clear the stat data.
For each data point, enter the number followed by SIGMA+
If you have grouped data, enter the number followed by 2ND [FRQ] followed by the frequency then SIGMA+
Press 2ND [sigma x n] for the population standard deviation or 2ND [sigma x n-1] for the sample standard deviation.
21helpful
3answers
Standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
4helpful
2answers
Standard Deviation
I want to calculate a standard deviation on BA II plus
Standard Deviation
Texas Instruments TI-86 Statistics How-To Information The following instructions should allow you to calculate the mean and standard deviation using a TI-86 calculator.
  1. Press STAT
  2. Select EDIT
  3. Enter data into a list: [2.32 ENTER 2.43 ENTER 2.39 ENTER, etc.] Continue until all data have been entered. (use arrows keys to go to the y value, if any)
  4. EXIT until you reach the main ("blank") screen. (If you try to calculate while you're in the data menu, it thinks you're still trying to enter data!)
  5. Press STAT
  6. Select CALC
  7. Select OneVa
  8. Select LIST, NAMES, xStat(F2), Press ENTER
  9. The calculator provides Max, Min, Mean, Standard Deviation, Sum, Sigma, etc. You will be primarily interested in the Mean and Standard Deviation (sx).
2answers
Standard deviation
StdDev( {1,2,3,4,5,6,7,8,9,10} )
with your list inside the curly braces.
1helpful
2answers
Standard Deviations
This calc will do standard deviations. In the manual it is on page 2 and also on page 40.
Top Casio Office Equipment & Supplies Experts
Sudeep Chatterjee
Sudeep Chatterjee
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
