SOURCE: receive faxes but can't send
Instead of trying to send a fax try to call the number from a different phone. To see if the receiver is busy all the time..
SOURCE: NEED ERROR CODE TRANSLATION
I do not know what the error code means but try this http://www.sharpusa.com/global/ContactUsProdSupp/1,1878,,00.html
They should be able to fix your problem
SOURCE: Receiving faxes, won't send faxes. Comes up line
Your fax machine thinks everything is OK. If you can receive you can send.
call the failing fax number with a regular phone and listen for fax tones.
SOURCE: Fax will send but not receive faxes. Says printer
Mite need to clearthe memory of the fax machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
