Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Posted on Jan 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does the error code LF mean? - Whirlpool Cabrio WTW6600SBT Top Load Washer
Anonymous
Level 2:
  • Expert 45 Answers
  • Posted on Jan 17, 2010
Anonymous
Expert
Level 2:
Answers
45
Questions
0
Helped
8562
Points
124
It should mean low frequency (of electricity), but it could be something else, sorry
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Dec 15, 2007
SOURCE: Lf what does it mean?
LF = Long Fill
Is water supply connection turned on.
Are hose screens plugged? ( these are inside the inlet on the machine where the hoses connect )
Is water entering the tub? If so, check the pressure hose connection to the machine/motor control. This is the main control unit. There is a service manual inside the machine. If you open the top of the unit with a screw driver in the front, the manual should be on the inside of the front panel.
Anonymous
  • 6 Answers
SOURCE: Kenmore Oasis HE 2708..LF error code
LF = Long Fill
If the water is on and screens are clean there is a test you can do to check the log valve. There should be a repair manual inside the front panel of the machine. If yo use a screw driver in the front to open the top you should find it on the inside of the front panel. Good Luck
Anonymous
  • 15935 Answers
  • Posted on Sep 11, 2010
SOURCE: what does the code LF mean?
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Anonymous
  • 18 Answers
  • Posted on Nov 07, 2010
SOURCE: I have a whirlpool Cabrio, what does LF error code
The LF error is a water supply fault. Both water supplies must be connected and fully opened. The inlet hoses and valves both have strainers that may need cleaning as this could obstruct the water flow and also check that you don't have any water leaks. The unit requires a minimum water pressure to operate so anything that could prevent the unit getting this pressure will cause this fault. Hope this helps you out!
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Nov 01, 2011
SOURCE: whirlpool cabrio error codes
Hello, stefanie
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Logik LPE 10 HP portable air conditioner. Lf error code on LPE 10HP BUT THE WATER TRAY IS EMPTY AND it HAPPENS EVERY 5 MINuteS
Question edited for a lot more clarity 'make model (what it is)'.
Question moved from Washing Machines
Please don't type in all CAPS, it is considered SHOUTING and is harder to read.
There doesn't appear to be an 'Lf Error' anywhere. 'Low Freon', no idea, it's a guess?
https://www.google.com/search?q=logik+lpe+10hp+LF+Error+Code
https://www.google.com/search?q=air+conditioner+LF+Error+Code
1helpful
My cabrio whirlpool washer automatically restart new wash
Well, is it LT, or LF? They mean completely different things.
Maytag 2000 Error LF what does this mean
The LF error code indicates a long fill condition.
What you need to do is check the filter screens where the hoses connect to the unit. Remove the hoses at the back of the unit. The screens are hust inside of the connections. Make sure they are free from any debris.
or
https://www.youtube.com/watch?v=1M-XgRT3obc
or
http://ths.gardenweb.com/discussions/2441868/maytag-bravos-lf-error-code-solved
How to clear error 6000 canon410
Line Feed error or Error Code 6000
Condition: An error occurred in the LF encoder signal.
Problems and Solutions:
  • Smearing or scratches on the LF / EJ slit film
    - clean the LF / EJ slit film.
  • Foreign material or paper debris in the LF drive;
    - remove foreign material.
  • If other solution fail, replace one off the following
    - LF / EJ slit film
    - LF / EJ timing sensor unit
    - Paper feed roller unit
    - Logic board
    - Paper feed motor
What does the error code "lF" mean
Do you mean "LF" if so that's a "long Fill" code. usually means the machine is taking to long to fill. Check your water supply line. Make sure the faucets are fully open, no kinks in the hose's or sediment in any inline filters etc.
1helpful
F error code "kenmore top load" washer oasis he3
Hi
LF means Long Fill, this error flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change. Check whether water supply is connected and turned on. Make sure the hose is not blocked and hose screen is clear. If so make sure pressure hose connection to machine/motor control is fine. Also check the continuity of water inlet valve, use a multimeter to check the continuity. Hope this helps... Please post back if you need more information.
Daniel
Code LF on Kenmore Oasis washing machine.
Hi
Error code LF means long fill. This means that analog water level pressure sensor signal is out of range or the water pressure is very low. The analog pressure sensor is a component on the machine control board. The normal water pressure is 100-200 PSI, when the pressure below 40 PSI then this error occurs. Verify the pressure at all other water sources in the house and check if its low at all places, if its low then contact the water company. Also check the inlet water hoses if they are kinked. Inspect the inlet water valve as well.
If you find no problems with the air hose or water pressure and its connections, then the machine control board would need to be replaced.
Please post back for any further assistance.
Daniel
What does LF mean - my kemore washer quit working
hello
mean while LF error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
The LF error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the LF error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
6helpful
Washer has LF error?
Lf means Long Fill This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. Good luck
Narseman
