Canon imageRUNNER 3035 Black and White Copier Logo
Posted on Jan 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code E000007-0000 - Canon imageRUNNER 3035 Black and White Copier
  • Anonymous May 11, 2010
    E007 is fixing related error! You need to change the fixing film. After replacement of fixing film, replace the cleaning roller of pressure roller.Change the cleaning roller every 10-15K copys to prevent premature fixing problems. If you have over 300 000 copys change the press.roller bushings and rubber ring , if you have over the 500 000 copys the best solution is to replace the whole fixing unit, little expensive but worthed
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2918
Points
6
I have machine of canon ir3300 this time show this problem in machine E0000007-0000.
Anonymous
Level 2:
New Friend:
  • Expert 170 Answers
  • Posted on Jan 14, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
170
Questions
0
Helped
48432
Points
280
There is something wrong in fixing unit check the fuser film maybe thats part is worn out
Sata Duhok
Level 1:
New Friend:
  • Posted on Oct 23, 2014
Sata Duhok
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2918
Points
1 Related Answer
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on Apr 28, 2009
SOURCE: I have a problem with code ''E000007-0000'' (canon IR2230)
A E-000007-000 means that the fixing film in the fixing unit can not find the "Home Postion" for the film. Most likely the fixing film is ripped and the film has proble moved to one side. Basicly you are going to have to have the film adjusted back to HP or the film needs to be replaced. Have you seen any little pieces of thin Black plastic come out of the copier, also is the toner not bring fixed into the paper.... Good Luck..... You may need to call in for reinforcements to solve the code... It will not clear till it is repaired
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
