Codes for rca remote rcu404n
SOURCE: I need code for rca rcr461 universal remot my tv is a ilo
1. Manually turn on the component you want.
2.Press and hold the TV, DVD etc the illuminated component names turns on.
3.While holding the compnent key down simultaneously press and hold the ON.OFF key - the illuminated name turns off.
4. After holding down both keys for 3 sec, all components name stay on.
5.Release both keys. the component name remains lit.
6.Press and release the PLAY key, wait for 5sec, the component will turn off. If component does not respont continue to press PLAY every 5 sec until component turns off.
7.When the component turns off, then the correct code is blocked. Press REVERSE key wait 2 sec to see if component turns on again.
8. Once component turns on then use STOP key - now code is stored.
Note: use FORWARD KEY AND REVERSE KEY to go front and back on the code search.
(sorry for the typo (if any) I dont have a scanner to scan the manual and I am typing out from the manual)
SOURCE: ilo tv control broke. bought a rca rcr312w remote,
I was unable to find a code for your remote but...The GE universal remote #24914 works all features on your Ilo tv. The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10.Hope this helps you.
SOURCE: Need a remote code
I am sorry to say that your brands are not listed in code list..
but try these codes : 456, 458,026,820,487
or run code search
Press and hold CODE SEARCH
until the INDICATOR LIGHT
lights, then release CODE
SEARCH.
2. Press and release the device
button for the device’s code
you are retrieving (TV,VCR or
DBS•CABLE). The INDICATOR
LIGHT will blink once then
remain lit.
Note: For AUX, press DVD•AUX
then the device button for the
code you are retrieving.
3. Press and release CODE
SEARCH. The INDICATOR
LIGHT will turn off.
4. Starting with 0 on the keypad,
press the number buttons in
order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the
INDICATOR LIGHT to blink is
the first digit of your code.
6. Repeat step 4 until you have
retrieved all three numbers in code
SOURCE: i have an rca rcu404n
RCA does not list a code for the Trutech TV. Trutech says that their TV is not compatible with universal remotes.
Some people have said that they had luck with Daewoo codes. You could try 016, 190, 005, 171, 004, 006,
017, 127, 196, 202, 222.
If that does not work, you might also try the code search method.
