Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
Posted on Jan 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Info code=021 - Panasonic Panafax UF-885 Plain Paper Laser Fax
Anonymous
Level 2:
Scholar:
  • Expert 108 Answers
  • Posted on Jan 03, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
108
Questions
0
Helped
30749
Points
339
Press
Function
7
monitor key slowly 4 times
6
scroll sdown to SHIPMENT SET
set
wait for the machine to initialize
2helpful
My UF585 said printer error info code 021. Please tell me how can fix it.
Press
function
7
* star key
6
scroll down to SHIPMENT SET
set
wait for reboot
Printing Error Info Code 021
It sounds like you had a power failure.
Press
function
7
asterisk key *
6
set
set
fax machine should now reboot,
13helpful
3answers
Error code 021
Press
Function
7
monitor slowly 4 times
6
set
wait for the fax to initialize and come back to READY
1helpful
Panasonic uf 590 problem printer error info code 021
press
function
7
monitor key 4 times slowly
6
set
set
wait for the machine to re-intialize
3helpful
3answers
Printer error Info code=021
Hi, machine error/info codes usually require service. Attempting the following involves some risk, you may loose complete access to your unit or not do anything at all. It is strongly recommended that you call a qualified service personnel/professional. However, if you feel like giving it a try while praying..... reset the system: Power on, wait for a minute or two, Function button, 7 (keypad), Monitor button (4X), soon as you hear the beep punch * (keypad). You will now be in the service menu. If no service menu, stop, do not power off, unplug. If in service menu, 7 (keypad), Set, go to Reset Option (arrow down one step), Set. Unit will prompt you to reset, press 1 for yes, system will confirm that it has completed resetting. Go back to main menu (Stop button), power down, wait again for a minute or two, power up. Please remember that resetting may, can and will erase all your personal settings and preferences including day/date/time, etc. The above steps may make your unit completely useless. If still you have the 021 code, you can brute force it to reset. Power on without a toner cartridge. In self-test, it will check itself and reset many functions to determine faults (including toner cartridge and your code 021). Wait again for a minute or two, Power off, reinseert the toner cartridge, wait again for a minute or two, and power up. If all else fails (including the prayer) pls go back to the first paragraph. The above steps are not mine but were described by a good samaritan. Hope this works out for you and lots of luck.
1helpful
We are not able to recive fax
this code means the fuser unit has gone over temperature, as a sftey feature the mc will have to have the fuser unit reset then if the reset (which is done through service mode) doesnt fix it then it may need a new thermostat or lamp.
Problem with fax machine
I see that when there is not paper in the cassette or the cassette is not shut all the way.
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
