Broan-NuTone Nutone Utility Exhaust Fan 210CFM 7'' Round Ceiling Fan - 8210 Kitchen Hood Logo
Anonymous Posted on Jan 01, 2010
How do you wire a duplex switch with one common hot wire to two fans. TWO SWITCHES ON ONE CICUIT?
  • 1 more comment
  • Anonymous Jan 01, 2010
    it's not a three way switch but a combination two switches
    http://www.amazon.com/gp/product/images/...
    How can I wire two fans on the same common feed circuit to the switch?
  • Anonymous Jan 02, 2010
    OK. Have BLACK power wire going to black screw.White wire wired into other 2 white fan wires. Two BLACK fan wires to each gold screw of switch. All ground wires connected together. OK, have done this but motor burned out again.
    Looked at double switch in bathroom with no ground wires (old wiring).It has a red wire and white wire going to the switch with black wire on black screw of switch. Not sure how the switch gets it's power but it works controlling the fan and lights separately.
    Need to know step by step starting from scratch how to wire an exhaust fan (currently a NUTONE 8310).What breaker,what type of wiring and the best wall switches to use?
Anonymous
Level 3:
  • Master 8,197 Answers
  • Posted on Jan 01, 2010
Anonymous
Master
Level 3:
Answers
8197
Questions
7
Helped
3120373
Points
27242
You are tiring to hook up a 3 way switch. It is not that hare. just look at the diagram on link below.
online
.com/3waydiagram.htm">http://www.electrical-online.com/3waydiagram.htm
  • 1 more comment
    This link has all the different ways you can do it.
    http://www.homeimprovementweb.com/inform...
    So you have 2 fans and one switch with 2 toggles on it. Here is how to wire. If you have any questions please ask.
    Do you have a wire coming from each fan to the switch box. if so you are good. if this is the case then you take the hot wire and you put to the black screw side of switch and the black wire from one fan to the gold screw on other side. repeat for other fan black wire. then you wire nut all the white together.
    If you only have one wire coming from the fan to te switch box then you need to run a new wire from the fan that does not have a wire going to the switch box and wire it up like mentioned above.
    You need to figure out if the black wire it the hot or is the red wire the hot. If they are both hot you only use one hot wire on the switch. The other reason you are blowing the moter is when they put the wall board on the wall there can be a screw in the wire giving it a short. You might need to get a electrition out to check the wireing.
Top Broan-NuTone Kitchen Ranges Experts
Paul Bade
jdthefixer
ADMIN Andrew
ADMIN Andrew
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
