SOURCE: Epson CX11NF Error Message Service Req E511
Check my previous post that explains the E511 error in some cases:
http://www.fixya.com/support/t612937-service_reqd_e511
SOURCE: Epson Aculaser C1100 Printer suddenly stopped printing
hi,
where is the dustbin button? i have looked but dont see it pls explain.
thanks
Carmen
SOURCE: Service Req E511
E511 is a TRO sensor error (cannot detect rotation of PCU belt), don't panic its probably just a dirty sensor. Turn off & raise the scanner unit fully & open the top printer cover. Lift the orange lever and lift the PCU out of the printer using the strap. First of all turn the PCU onto its back but avoid any bright light on the blue roller (it's called the "Drum" and it is light sensitive and very easily scratched so be careful with it and avoid touching the blue surface if possible). Rotate the white plastic gears at the ends of the drum until a little silver square appears in the cut-away section of the cover, this reflects the light onto the sensor so make sure it is cleaned with a soft cloth. Next look inside the printer and you will see a metal strip running across from side to side, mounted on this is the TRO sensor. Give this a clean also with the cloth. One more thing to clean is the sensor at the back, you will see a small black plastic spring loaded lever, push this down and wipe the sensor. Do not try to lift the lever back into position, it will spring back when the PCU is refitted. Refit the PCU, close the covers and give it a try.
If still not working the cause is either a faulty MCU board or possibly a faulty PCU, but to be sure it will need checking by a repair tech as diagnosis by email is difficult.
Good luck, please take a moment to rate this solution, thanks.
SOURCE: error service req E511, all lights flashing
Possible parts that caused the error
1 Photoconductor Unit 2 SENSOR TR-0
3 HARNESS-ASSY XERO 4 MOTOR ASSY P/R
5 HARNESS ASSY MAIN 6 PWBA MCU
7 LV/HVPS
SOURCE: espon aculaser c1100 service req e511
Error E511 is due to ur photoconductor.. the black transfer belt is out of position... it can be corrected if you know how to open up the photoconductor unit...
1. Replace Photo conductor unit 2. Clean TR0 Sensor If not solved Possible parts that caused the error Photoconductor Unit, SENSOR TR-0, HARNESS-ASSY XERO , MOTOR ASSY P/R HARNESS ASSY MAIN, PWBA MCU LV/HVPS
