Hello there
the Dreaded E20 fault is a drain problem
washer will show the E20 code and may
not spin.
So i would first look for a clog in the hose right before the water pump there is
a little cup in the black hose that could be full of suff if so empty the
cup and it should work good after this
hope this will help you out
Best regards Michael
Hello Diane Snow, thank you for your inquiry!
I understand that your Frigidaire washer is displaying "E20" error code. The "E20" error code means water is not pumping out fast enough. First, you want to check the hoses for restrictions.
If the hoses are not restricted it could be an issue with the drain pump or control board. I would suggest seeking assistance from a professional technician for proper repair. I hope this is helpful. -Matt
