Dear Sir
I Have Compaq nx6115 Laptop but Ethernet Card is not istalled properly . we try to download from HP compaq Site but it is also not working .
kindly suggest how to install the driver and any link
sanjay singh
sanjay.singh@dalmiacement.com
Pls reconnect the Ethernet cable back to the other PC and check how is its getting IP address, automatic (Obtain an IP...) or fix (Use the following...). To do this go to your Control Panel, click on Network Connections, right click on Local Area Connection, click on Properties, highlight Internet Protocol (TCP/IP), click on Properties button. If it is the latter, note down the numbers.
Plug the Ethernet back to your laptop and do the same. Set your laptop's Internet Protocol Properties to mimic the other computer settings. The only possible difference would be is if the other computer is ticked on "Use the....", the IP address of the laptop should be different from the other PC. Example if the other PC is 192.168.1.5, make the laptop 192.168.1.6. All others stay the same.
Hope this ne of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
same issue
