Microsoft Windows 98 Year 2000 Update  for PC  Logo
Posted on Dec 19, 2009
Error code 646 - Microsoft Windows 98 Year 2000 Update for PC
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Dec 21, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
3914
Points
13
Hello Titan,
Try to disable your firewall. If you’re using McAfee Personal Firewall Plus, F-Secure Internet Security, Norton Internet Security or another Firewall vendor, see its respective support page for assistance in disabling it (temporarily). If you’re using the built-in Vista Firewall, keep reading.
* Open the Control Panel and select Security.
* Select Turn Windows Firewall on or off.
* Select Off (not recommended), click Apply and then OK.
* Back at the Windows Update screen, click the Try again button.
* The download(s) and installation should start…
* and this time successfully install. If a restart is required, make sure to re-enable your Firewall once your PC restarts.
* Though this solution will work for most Vista Update errors
Regards,
Soul_srch007
1helpful
Radio Code Alfa Romeo Brera
ALFA ROMEO 159 / ALFA 939 CD SB05 BLAUPUNKT 7 646 302 316 CAR STEREO ONLINE CODE SERVICE https://www.carstereocode.com/unlock.php?id=779
I can't install Windows updates and get error code 646.
1. If you Operating System is due to registry errors, you can try the registry cleaner @ http://windows-error-repair.org/error-library/error-code-646.html
2. Check your security programs eg. firewall or internet security programs, disable it and try Windows Updates.
3. Scan your PC for any Malwarewares or virus infections.
Hope it helps.
I cannot receive microsoft updates, they fail. Error 1606
The error code 646 will appear when any of the Microsoft office application updates fail to install. Run fixit provided in the below link and then try to install updates.
http://support.microsoft.com/kb/971058
2answers
How to fix this problem
http://www.vistaheads.com/forums/microsoft-public-windowsupdate/322548-error-646-a.html read that page, has all the info you need on how to get info and the official MS page to fix it.
Should be able to help you properly
Try to download updates and get error code 646
sounds like your internet connection is compromised. From Compaq's error code management page. see here for details
Error message 646
Alright here is what you do.
Go to support.microsoft.com and type the name of the updates that are failing.
Once you download them on your computer, Right click on them, and Run as Administrator. This way, you will not get any errors.
Do let me know if that worked, otherwise, we can find something else.
2answers
Update KB946140 and Error Code 646
Sometimes MS update has compatibility issue.Better no to install cause sometimes it can create a bug (Blue Screen Crash) to your system.Try to restore yor windows 7 to an earlier point and the error message gone.Also try to turn off your automatic update so that you can choose your update to be installed.
2answers
Code 646 when trying to update
You need to disable your firewall. If you’re using McAfee Personal Firewall, or Norton Internet Security or another Firewall vendor, see vendor support page for assistance in disabling it (temporarily).
- Open the Control Panel and select Security.
-Select Turn Windows Firewall on or off.
- Select Off (not recommended), click Apply and then OK.
- Back at the Windows Update screen, click the Try again button.
-The download(s) and installation should start…
-And this time successfully install. Now make sure to re-enable your Firewall once your PC restarts.
* Though this solution will work for most Vista Update errors.
Top Microsoft Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
