HP Photosmart C5180 All-In-One InkJet Printer Logo
Posted on Dec 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer said to replace yellow cartridge,replaced yellow cartridge,will notprint at all
Robert Kitaji
Level 3:
President:
  • Master 1,335 Answers
  • Posted on Dec 18, 2009
Robert Kitaji
Master
Level 3:
President:
Answers
1335
Questions
Helped
450270
Points
4245
If you are not getting an error message, your nozzles may be clogged. If you are using aftermarket or refilled cartridges, insert new OEM cartridges and run deep cleaning a number of times (3x) and the realignment utility. This should clear the nozzles and the cartridge sensors. Secondary market cartridges often do not meet manufacturer's specifications and can clog the printer nozzles. This should clear the problem.
1helpful
Scans but will notprint
It is probably out of ink. Check ink cartridges, or use the machine manufacturer's software to report on ink levels or on the status of the printer.
HP designjet T610 yellow cartridge error
If its yellow cartridge error, replace it, if "resit yellow cartridge" error, >check cartridge contact unit in iss unit,>inter change with another cartridge contacts unit & try for the diagnosis.> replace iss PCB..
My printer is not printing anything orange, it comes out pink. Just put in new cartridges.
It sounds like your yellow is not printing correctly (probably a clogged nozzle). If your printer has separate cartridges, replace the yellow. If you are using aftermarket cartridges, you should try using OEM cartridges since they are spec'd to the printer. If you are usng aftermarket or reloaded cartridges, the ink may not be up to specs. In any case the yellow ink cartridge needs to be replaced. Make sure to run a deep cleaning and alignment after replacing the cartridge.
2helpful
My watermarks are printing as pink instead of gray, this started happening after I changed the black cartridge. I have not made changes to the original document, and normal text still prints as black
if that is a refilled cartridge, you might have a problem with the ink. try print something (text) in pure black , and grey only, and see waht happens, if does notprint, means the printer has hard time with that black cartridge.
HP C6100 Printer does not like yellow cartridges
Hello sir; replace cartridge whichever it necessary, better buy oem.
SAMSUNG CLP-600N YELLOW CARTRIDGE DUMPS INK
Did you replace the cartridge with a genuine samsung cartridge or is it a refill or remanufactured cartridge?
Gremlin11
Display says I am out of yellow,
Hi, since you've already replace the yellow ink cartridge for several times and its not recognize. Your printer might have a defective printhead. You may take your printer to the nearest HP service center in your area so that they can look on your printer further.
---->> Tirzo
Lc 41y
i do not need a technical solution- all i need is how can i get a new yellow lc41y ink cartridge to replace a defective one
can i exchange the cartridge for a new one or
can i buy only a yellow cartridge
if neither i will have to buy another package and am stuck with defective yellow cartridge
i bought a package of 3 colors necessary to print in black- yellow wouldn't take - luckily i always have an extra package so i replaced the yellow and my printer works
but my extra package is now short a yellow cartridge-
my problem is outside the box - thanks anyway
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
