Make sure all the cable are connected tightley and check the pins in the end of each cable to ensure connection. Check the lamp itself, lamps usually run about $150 - 165 for this model, the timer beside the lamp can be reset but its just a lamp life timer. This will need to be reset when you replace lamp. If your a connected to a pc be sure the port is active an enabled. To reset the system you can unplug power cord for a few minutes and plug back in. It sounds like you have a cableing or lamp issue. If cableing is correct and no bad pins in the end, replace your lamp.
Look in the lamp menu... there is a lamp reset ... select it then select yes
Ok, but i don't know how to look in the lamp menu... because, the lamp don't start, It is not possible to navigate.
Is it possible to plug a screen ?
