STEP 1 : Download the Borland Compiler
https://downloads.embarcadero.com/item/24778
STEP2 : Run the setup program
By default, it should install everything to C:\Borland\BCC55
STEP 3 : Add the /bin directory to the system PATH
>C:\Borland\BCC55\bin\bcc32 OR >c32
After the setup program is run (step 2), a whole bunch of executable programs are placed in a new directory : C:\Borland\BCC55\Bin. This step makes it possible for the Operating System (Windows) to find these new executables by name. If you don't do this, then you will need to specify the full path to bcc32 every time you use it.
To do this on Windows XP
Bring up the Environmental Variables :
•Right Click "My Computer" ( Depending on how your system is set-up, "My Computer" is either on your Desktop or in your Start Menu )
•Select "Properties"
•Activate the "Advanced" Tab
•Click the "Environmental Variables" Button
Append ";C:\Borland\BCC44\bin" to the PATH variable (figure 3-2)
•Select the PATH variable under User Variables
Note: The PATH variable may appear under both System Variables and User Variables. This How-To changes the User Variable.
•Click the EDIT button below the list
•In the "Edit User Variable" box that pops up, move the cursor to the end of the Variable Value field
•Add a semi-colon ";" to the end of the current value
Note: If the value is empty, then you do not need to add a semi-colon
•Add the path "C:\Borland\BCC55\bin" after the semi-colon
•"OK" your way out of the dialogs
STEP 4 : Set up some configuration files
you should create a configuration file for the bcc32 program that tells it where to find its libraries and include files.
•The file should be named bcc32.cfg
•It should be placed in the same bin directory where bcc32.exe is located
(C:\Borland\BCC55\Bin)
•The contents of the file are the command line options for bcc32 stating the location of include files and libraries:
-I"C:\Borland\BCC55\Include"
-L"C:\Borland\BCC55\Lib"
Regards,
Soul_srch007
