Philips PM3S Remote Control Logo
Posted on Nov 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I lost my code sheet and I need the code for a Symphonic TV
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 212 Answers
  • Posted on Nov 20, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
212
Questions
0
Helped
66269
Points
676
If your product does not respond after you have tried all
the codes for your brand, or if your brand is not listed,
try searching for your code by following these steps.
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH
button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Most users will store VCR codes under the VCR button,
Cable codes under CABLE, etc. If (for example) you
want to store a VCR code under CABLE, first follow the
procedure for Direct Code Entry (previous page) and
press CABLE in step 2 of Direct Code Entry, then enter
ANY VCR code in step 3 of Direct Code Entry. Then
follow the steps above for Code Search (or Brand
Search, below). Note: If the device does not have a
CHANNEL UP button, use PLAY (VCR only) or
POWER instead. Code Search starts from the currently
stored three digit number under that mode. Good Luck.
5 Related Answers
lizwbuck
  • Posted on Jan 16, 2008
SOURCE: tv codes
i have a super scran tv, lost code for my tv
thanks for some help
Anonymous
  • 97 Answers
  • Posted on Jun 18, 2008
SOURCE: philips universal remote codes for symphonics tv
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Anonymous
  • Posted on Oct 12, 2008
SOURCE: Rrmote control codes
i need the code for philips universal remote i lose the code
Tony Walker
  • 393 Answers
  • Posted on May 11, 2009
SOURCE: I lost my philips universal remote sru 3003 manuel
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
hope this helps
Anonymous
  • Posted on Dec 08, 2010
SOURCE: I have a Dynatron DYN100Z remote I need to set it
1. Turn your TV ON.2. Hold down "Code Search" until the red light turns on. 3. Click the (+) Channel button once each second, until the TV responds by flipping a channel. 4. One the channel changes, press the, "ENTER" button. 5. Code is saved!
Top Philips Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
