Canon PowerShot SD110 / IXUS IIs Digital Camera Logo
Posted on Nov 08, 2009
How does self timer work? - Canon PowerShot SD110 / IXUS IIs Digital Camera
Anonymous
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Nov 08, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
10157
Points
71
Once you release the shutter button it will start to count down, at the end of 10 seconds it will take the picture.
I highly suggest using a tripod or if not a stable surface to sit the camera.
So I have an EOS Rebel Xsi, and it has been working perfectly for the last couple of months. I turned it on and tried to take a picture in MF, but then a yellow light on the front starts flashing and...
Sounds like the self timer was accidently set.
Description
Using the Self-timer on the EOS REBEL T3i.
Solution
The self-timer is useful when you want to photograph yourself or prevent camera shake caused when the shutter is released.
1. Set the power switch to <ON>.
2. Press < > button.
3. Press <Cross Keys> to select the desired self-timer, then press the <SET> button.
: 10-sec. self-timer (The remote control can also be used.)
: 2-sec. self-timer
: 10-sec. self-timer plus continuous shots. After selecting , press <Cross Keys> to set the number of multiple shots (2 to 10) to be taken with the self-timer.)
4. Look through the viewfinder, focus the subject, then press the shutter button completely.
  • You can check the self-timer operation with the self-timer lamp, beeper, and countdown display (in seconds) on the LCD monitor.
  • Two seconds before the picture is taken, the self-timer lamp will stay on and the beeper will sound faster.
Attention:
With [ ], the interval between the multiple shots may be prolonged depending on the shooting functions settings such as the image-recording quality or flash.
NOTE:
  • After taking self-timer shots, you should check the image for proper focus and exposure.
  • If you will not look through the viewfinder when you press the shutter button, attach the eyepiece cover. If stray light enters the viewfinder when the picture is taken, it may throw off the exposure.
  • When using the self-timer to photograph only yourself, use focus lock on an object at about the same distance as where you will stand.
  • To cancel the self-timer after it starts, press the < > button.
1helpful
How does self -timer work on canon power shot A2200
Press cursor-down (marked with a one-handed clock) then select the self-timer. Start the self-timer by pressing the shutter release button as usual. For full details see the "Using the Self-Timer" section in the manual (beginning on page 60 in my copy). If you need a manual you may download a copy from here.
Jan 18, 2013 • Cameras
1helpful
How does self -timer work?
Press cursor-down (marked with a one-handed clock) then select the self-timer. Start the self-timer by pressing the shutter release button as normal. For full details see the "Using the Self-Timer" section in the manual (beginning on page 60 in my copy). If you need a manual you may download a copy from here.
1helpful
How does self-timer work
A55 Sony camera self-timer audio not working-
If it still works, don't worry about it. Others around you may appreciate the peace and quiet as well.
2helpful
2answers
How do I use self timer. I set in on menu and I
In the REC mode, press [MENU]. On the "REC" tab, select "Self-timer" and then press right. Use up/down to select the timer type and press [SET].
I need help with setting the self timer on the Olympus Camedia c-700 camera. Can't figure how to do it with the menu. Any help would be greatly appreciated, Thanks
the self timer usually works like this.
find the self timer setting and set it to 5 or 10 seconds.
then exit the menu and click the button that you normally press to take photo. the self timer will start automatically and the picture will be taken after 5 or 10 seconds (depending on what you set).
note that the self timer will be reset to off after this.
I can not set the self timer. In the manual it says hit menue button go to "self timer" select the secons and shot hit "set" hit menu, hit shutter button fully. When I do this the Timer lamp doesn't...
The self timer will not work in the "Easy" mode (icon with a heart in it) or in movie mode. According to the chart in the back of the manual, the self timer should work with all other modes.
How to work the self-timer on the canon A560 digital camera
Once you have the self-timer set, simply press the shutter release button as you normally would to take a picture, and the timer will start.
2answers
I can't find the self timer
Does it have a self timer - check the manual?
Does it work at all with a broken screen?
Time for a replacement - camera that is.
Top Canon Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Canon Camera Expert? Answer questions, earn points and help others
