Washing Machines Logo
Posted on Nov 07, 2009
FP fault code on whirlpool washing machine - Whirlpool Washing Machines
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 07, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1340
Points
11
I have a whirlpool 6th sense awo 10761 and evrytime i start a cycle it stops and the door lock light flashes can any one help me
Anonymous
Level 1:
New Friend:
  • Posted on Feb 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1340
Points
Thanks of other one on NET, I change only "Brush,carbon motor CESET" at main motor and everythink works. I want say thanks to him but I miss link. I hope it can help to other one too.
5 Related Answers
Anonymous
  • 770 Answers
  • Posted on Jan 26, 2008
SOURCE: fault code
I have look over the codes for your model and dont see an FH code if you post your email here i will send you the service manual
issy2
Mohamed Ismail
  • 462 Answers
  • Posted on Apr 20, 2008
SOURCE: I keep getting an FP
whats the model no of your washing machine..?
Anonymous
  • 5911 Answers
  • Posted on Jul 03, 2008
SOURCE: Fault code C1
"C1" is known as an Instantaneous Current Limit Error. This will occur when the Motor Controller detects a current spike of 26 amps or greater at the motor windings. Overloading the washer, excessive water and/or excessive suds can cause this problem.
The manufacturer recommends the following:
- Wash smaller loads and use the correct detergent (HE only for Calypso machines). NOTE: Make sure the HE detergent is not double or triple concentrated as this will also cause suds problems.
- Check for objects under the nunate plate. This is the wash plate. Sometimes clothing can get stuck under the plate and cause the motor to bind up. To remove the nunate plate, follow these instructions:
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back against the wall in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the center cone from the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Clothing can get tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly. Don't forget to put the tub ring back in.
- Check for objects stuck between the inner wash tub and the outer basket. NOTE: It is best to do this with the nunate plate removed. Use a flashlight to peer through the holes in the wash basket to see if anything is catching on the tub.
- Check the Motor Controller. You will need to determine if there is power getting the the board first and that the fuse on the board is good. If any components on the board are defective, the board has to be replaced. If you have power to the board and the fuse checks good, check for continuity between the Machine Controller and Motor Controller.
There is a tech sheet inside your washer along the interior cabinet (usually the front panel) that explains all these procedures to you. I would advise you to research the tech sheet for exact locations of the pin outs for the circuit boards. Its easier for you to view it rather than me explain it. If you need further assistance, please post back and let me know. I hope this helps you.
Anonymous
  • Posted on Dec 29, 2008
SOURCE: fp fault
The problem is pump is either broke or there maybe something is caught up in the impellor, easy to fix, remove front cover undo spring for door seal unplug electrics, remove both hoses on pump and undo bracket, then check pump, had same problem myself it was an elastic band and coins got it fixed myself saved a fortune hope this helps.
Anonymous
  • 3513 Answers
  • Posted on Oct 13, 2009
SOURCE: my whirlpool washing machine won't spin. In the
Hi
Remove pump and check the pump for any foreign objects which is stopping the impellor from turning.
hope this will help.
Thanks for contacting fixya.com
Narseman
