Tablets & eReaders Logo
Anonymous Posted on Nov 03, 2009
Disassembling PDA's Can you help me for disassemble with my PDA iPAQ 110?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 04, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
126
Points
I have solved my problem vith PDA's already. Simply. I opened housing of PDA's and checked connect to screen. Thank you for intrest about to solve my problem. Hi Zdenek.
tip
DISASSEMBLING AND CHARGER CHECKING
LENOVO S5000-F - S5000-H
Checking the Computer AC Charger
When you use the computer AC Charger to charge the tablet but no power is charged, see the instructions in this topic to check the computer AC Charger.
To check the computer AC Charger, do the following:
1. Disconnect the micro-USB cable from the tablet.
2. Measure the output voltage across the connector marked B of the micro-USB cable. Refer to the following figure:
For more pictures and description check the link bellow. On search tab type Lenovo
www.electro-medical.blogspot.com/
google.com/+AjinGopakumar
How to diassembly my tablet
Don't know what brand/model you have so can't tell you.Try Google - disassemble (brand/model) tablet. Unless you are installing additional memory it is not adviseable to disassemble it if you have to ask how to do so.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
If you push on the screen everything shows for a few minutes...then goes white again or black again.
The connector / ribbon cable on the screen may need re-seating correctly or the screen itself is faulty, it is not possible to say which without disassembly. Unless you know someone who is prepared to disassemble for little money or as a favour it it is not economically viable to repair.
I would like to know how to disassemble Compaq TC1100. Disassemble keyboard from screen unit.
There is a latch that you need to pull to seperate the keyboard base from the slate tablet pc. This latch is located behind the monitor where the keyboard attaches to the monitor.
How do i replace the battery on gateway cx200x
remove main battery by sliding battery lock to unlocked position, then slide battery release latch and slide battery out. If you are looking for how to disassemble the notebook to change the bios/cmos battery, you can get the service manual at mpcdriver.com with complete disassembly, reassembly instructions and pictures
2helpful
Need to disassemble
to remove the keyboard on the cf-18 keyboard you must remove the 4 screwsby the ESC, F4, F10, and PAUSE key. once removed lift the 2 covers and holding the keyboard from Function key sides lift up slowly. There are 4 sticky tapes holding the keyboard, once some of the tapes are off you can slide the keyboard up towards the LCD to remove. The connector to the keyboard can be removed by removing 3 screws from the aluminum center cover found under the keyboard
Top Compaq Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Anonymous
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
