HP Pavilion a620n (PC028A) PC Desktop Logo
Anonymous Posted on Oct 27, 2009
What is the maximum memory for this computer?
Anonymous
Level 2:
Scholar:
  • Expert 107 Answers
  • Posted on Oct 27, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
107
Questions
0
Helped
29712
Points
267
This computer (HP Pavilion a620n) has 2 x 184-pin DDR DIMM sockets and supports up to a maximum 2 GB of memory. It supports unbuffered PC2700/2100 non-ECC DDR SDRAM memory. (Also known as DDR333 and DDR2100 respectively)
Testimonial: "Thanks..."
Mitch
Level 2:
Scholar:
  • Expert 40 Answers
Mitch
Expert
Level 2:
Scholar:
Answers
40
Questions
Helped
31181
Points
111
The MAX memory for this particular model is:
2.0 GB of PC2700 DDR SDRAM DIMM
Since the HP Pavilion a620n PC is equipped with two expansion slots for memory, each slot can support up to 1.0 GB of RAM for a total or MAX memory of 2.0 GB (1.0GB x 2 sticks of RAM)
Hope this helps!
See: MemoryStock.com
Anonymous
Level 3:
President:
  • Master 1,901 Answers
Anonymous
Master
Level 3:
President:
Answers
1901
Questions
5
Helped
782696
Points
6406
The max that computer will handle is 1GB (2 X 512MB) of PC2700 unbuffered, nonECC, DDR SDRAM.
See: HP a620n Specs
You can also go to www.crucial.com and run their system scan. It will tell you what you have, what it will hold, and what kind it takes.
Thanks for using Fixya.
  • Anonymous Oct 27, 2009
    Suggest you run the system scanner. HP has conflicting max amounts. One place has 1GB, another has 2GB. The scanner will tell you for sure.
    Thanks.
What is the max ram I can install on my Gateway MA 3?
Pull up a RUN box. Windows key plus R. Then type in cmd and hit enter. Next, using the command prompt that has appeared, type in wmic memphysical get MaxCapacity, MemoryDevices
Hit enter.
Copy the number you see and devide that by 1048576
You can actually do that in the address bar of your browser.
That will give you the maximum gigabytes your computer will run.
https://www.maketecheasier.com/how-to-find-out-maximum-ram-capacity-of-computer/
What type of Ram for dimension 3100, and how much ram is the maximum
Try 4 all memory at:
http://www.4allmemory.com
The link below is a direct link to your model. It state's that there are 2 slots in your computer and that it will hold a maximum of 2 Gigabytes (1 Gigabyte in each slot). The Memory Type is: DDR2 PC2-3200 or DDR2 PC2-4200
http://www.4allmemory.com/memory/dell-dimension-3100/
My system is recognizing only half of the new module's memory
Do you have the right memory for your Dell?
Memory Upgrade for Dell Dimension 1100 Computer, the Dell Dimension 1100 Computer takes the PC2700/3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Dell Dimension 1100 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Dell Dimension 1100 Computer.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
How much memory can I ad to a SR1802HM computer and do I need an external hard drive to handle more memory?
Maximum allowed 4 GB* (4 x 1 GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Maximum allowed 4 GB* (4 x 1 GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be lessThere will be 4 slots for the memory, you can use 4 memory cards of 1 GB each meaning thereby u can use 4 GB maximum.
2answers
Memory (Upgrade-Max) how I buy for the ASUS L 7200?
You could have tried GOOGLE.
Your computer has 64mb ram built in and can take a maximum of 320mb. You have 1 slot to add memory too
You can add 256MB, 144-pin SODIMM, SDRAM, PC133
1helpful
2answers
I want to upgrade my memory on my Pavilion 513n,
FixYa is a product support website, and as such we do not delve into manufacturing. No we cannot supply ram memory.
I can supply you with the solution to your questions, however.
This is HP Support, and the main page for the Pavilion 513n Desktop PC,
http://h10025.www1.hp.com/ewfrf/wc/product?product=90384&lc=en&cc=us&dlc=en&submit.y=5&submit.x=6&lang=en&cc=us
If you click on > Product information > Product specifications > HP Pavilion 513n Desktop PC Product Specifications,
you can view,
A) What type of ram memory the computer uses,
B) How much is the Maximum Total Amount for the computer,
C) How much is the Maximum Amount for EACH ram slot,
D) How many ram slots
Look under the Memory heading.
Type - DDR
It's DDR Sdram
Speed - PC1600/PC2100
Tells you either PC1600 can be used, or PC2100.
PC1600 is DDR Sdram that operates at 200MHz.
PC2100 is DDR Sdram that operates at 266MHz.
{To expound:
Ram memory operates at a Frequency Rate. Slang for frequency rate is 'Speed'.
Mega = approximately 1 Million
Hertz stands for Cycles per Second
Example: PC2100 is DDR Sdram that operates at 266 Million Cycles per Second }
B) What is the Maximum Total Amount for the computer. (Motherboard)
According to HP it is 1GB.
{Maximum - 1GB (2 X 512) HP recommended maximum}
I believe this to be wrong. The Total Maximum Amount is 2GB.
1GB per ram slot.
I base this upon using the memory configurator's of several websites, that sell ram memory for the Pavilion 513n desktop computer, and looking at what the motherboard chipset for the Pavilion 513n will support.
The motherboard chipset is the Intel 845GL.
This chart found on Wikipedia, states what the Intel 845GL chipset will support,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
As you can see reading across from the 845GL subheading, and looking under > Max.memory, 2GB is listed.
Sources for online memory configurators,
1) Crucial.com
2) Tigerdirect.com
3) Newegg.com
4) Memory4less.net
In this case,
C) Maximum Amount for EACH ram slot is 1GB.
D) There are Two ram slots. {Proper speak for ram Slot is ram Bank}
Kingston is a good brand for economical ram memory.
So is Ultra.
An easy way to find out what type of ram memory you need, and how much is the Maximum Total Amount, as well as the Maximum Amount for Each ram slot, is to use an automatic scanner from a website that sells ram memory.
The above four websites listed, are but a small handful of the total websites online that offer an automatic scan.
Let's use Crucial.com for an example.
On the main page,
http://www.crucial.com/
,you will see - Scan My System, in blue.
Simply click on it to run an automatic scan of your computers hardware.
Doesn't look at your personal effects, just the hardware of your computer.
After the scan is done, you will be presented with the ram memory info you need.
Several options of ram memory are presented for you to choose from.
Does the acer aspire 5315 2077 require a certain type of memory?
Go to www.crucial.com and click on the scan my system button to see what configuration of Memory Modules are installed on your laptop.
Here are some other details:
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Chipset: Intel 960GML
Drive Form Factor: 2.5"
Drive Interface: SATA
Maximum Memory: 2048MB
Slots: 2 (2 banks of 1)
Standard Memory: 512MB removable
USB Support: 2.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR2 memory with support for DDR2 PC2-5300 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: Yes.
1helpful
Dual Channel on an Emachines T5082
Look closely at the BOLD print
Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
Can I increase Maximum Memory for 1800T?
No, The reason why your computer says it has lower memory is because either
A- your bios can only recognize up to 320mb. --possible fix via upgrading/flashing your bios --check manufacturer's website.
B- your on board video card shares memory with the system.
Top HP Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
