What file did you move? and when does it appear? do you need to go to that address any more? seems like its a temp file and that is no danger if they are missing. you can always delete temp folders.
if you have moved the file then it cant find it. but what is your problem then? do you need this file or ? does a error appear?
ok, have you tried to change homepage on your browser? try
tools>Internet Options>
and change homepage to www.google.com. and then click OK
ok, looks like you have some virus or something has messed up your system.
1. download this malewarebytes. install it and run "quick scan", before you do that inactivate your antivirus software(else it gonna be a collision). after the run remove everything the program find.¨
2. after that restart you computer and see if problem is gone.
3. you can also try after 1 and 2, to start computer in safe mode(f8 after bios logo) and delete the whole temp folder. (cannot find 'file://c: documents and settings/...../ local sittings/temp)
and restart your computer.
the computer shouldnt try to load any files from the temp folder.
temp folder is just for install files etc.
you can also check the msconfig for startup programs.
go run->msconfig
and then startup.
check for programs that have the temp folder as startup folder.
unbock if you find.
No not the TEMP file. I think it's a user file named " abu alfadel"
cannot find 'file://c: documents and settings/...../ local sittings/temp/...........html'
this error appears to me every time i open IE. The file I moved was located in ( Documents and sittings) Folder
Yes i tried that before and the error kept on shownig up. that's is not the problem you see after the error message and pressing ok IE opens on my home page (which is already Google)
