I have a Canon Powershot A520,everytime I turn the camera on I have to reset date and time?? Of course this is not diffcult to do but it is a pain.
Can anyone tell me why this is happening??
Thanks
Solution:
Replacing the date battery PowerShot A510 and A520
Replacing the Date Battery
If the Date/Time menu appears when the camera power is turned
on, the date battery charge is low and the date and time settings have
been lost. Please purchase a lithium coin battery (CR1220) and replace
it as follows.
Please note that the first date battery may appear
to expire relatively quickly after you purchase the camera. This is
because it is installed in the camera at the point of manufacture, not
when you make the purchase.
Be
particularly careful to keep the date batteries out of the reach of
children. Seek medical assistance immediately if a child swallows a
battery since corrosive battery fluids could damage the stomach or
intestinal wall.
After purchasing the camera and turning on the power for the first
time, although the Date/Time menu will appear, you do not need to
replace the date battery.
If you ever dispose of your camera, first remove the
date battery for recycling according to the recycling system of your
country.
Some models have a small battery hardwired to the motherboard to keep the 'clock' going when the camera id powered down.
These fail in time.
There is not replace or repair option.
Hey fixya do you think MAYBE you could stop breaking your image links to answers like these don't become practially useless?
SOURCE: everytime I turn the camera on the time and date
There are two batteries in the camera. One is the big one you charge and the other is a little coin type battery. This coin battery maintains your settings and when it goes your camera forgets things. Same setup on computers and a lot of other electronics. In your camera the battery is a CR1220 worth about $1-$2. It should last about 3-5 years but you never know.
The battery is in a little holder on the left hand side of the camera. Its under the same cover as the usb connector and power plug in. You should be able to pop out the battery holder fairly easily. This is one of those things that if you take the camera to a battery store they will probably do it for you if they aren't busy. If you look at page 137 of your manual you will find the instructions for doing it yourself.
SOURCE: every time I set the date/time on my camera and
Replace the date/time battery on the side of the camera.
SOURCE: Good morning, Every time I switch on my Canon
Yes there is an internal back up battery/capacitor on the main microprocessor board which is within the camera /backed up by the main battery. Please leave the main battery in the camera and see if this stays. If there is no other issue with the camera than this I would advise that you leave this off for the time being unless you are experienced to open and check and replace.
Thanks very much Merry Christmas
