Task 1 - Turn on the Discoverable option on the BlackBerry smartphone
Complete the following steps:
Task 2 - Pair the BlackBerry smartphone and the computer
On the computer, complete the following steps:
Task 3 - Set up the Internet access point name (APN)
Note: You only need to perform this task the first time that you set up the Internet APN.
Note: If you are running Windows Vista, select Classic View.
Task 4 - Configure Dial-Up Networking
Note: You only need to perform this task the first time that you configure Dial-Up Networking.
Task 5 - Connect the computer to the Internet using Dial-Up Networking
Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session may interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
If you are using a laptop with Windows Vista, click the Start Button and type Network and Sharing into the Start Search box. Select Network and Sharing Center from the Programs list. Select Manage Network Connections from the left pane of the window. The Network Connections window will open. Click on Wireless Network Connection. Select Disable this Network Device at the top of the window.
Troubleshoot the Network
Troubleshoot Network Settings
If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
