Philips Magnavox Learning Universal Remote Logo
Posted on Dec 22, 2007
Need code for universal remote for a sharp t.v.
  • 3Streets Apr 02, 2008
    Any1 have the code needed for an Insignia DVD/VCR recorder for this remote?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 22, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
85
Points
DOES PHILIPS MAGNOVOX UNIVERSAL REMOTE RUN SATELITE, AND IF SO WHAT MIGHT THE CODE BE?
Anonymous
Level 1:
  • Contributor 4 Answers
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2003
Points
5
5 Related Answers
Anonymous
  • Posted on Oct 19, 2009
SOURCE: I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Anonymous
  • Posted on Dec 27, 2007
SOURCE: universal remote
need a code for a philips remote to control a zenith tz
Anonymous
  • 97 Answers
  • Posted on Jun 20, 2008
SOURCE: Universal Remote control code on Sharp 13H-M60
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Anonymous
  • Posted on Dec 11, 2008
SOURCE: ECIRCUIT REMOTE CODES
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/ecircuit/6in1-manual.zip&area=other
Anonymous
  • Posted on Jan 25, 2009
SOURCE: remote code for my ge universal remote
here is all the codes for that kind of tv 0079 0123 0063 0020 0004
....... 0009 0226 0266 0006 0095 0122 one of these should work
I need to program a Sharp tv DVD combo to the cc'd remote.
Remote Control Codes For Sharp TVs
DirecTutor.com https://www.directutor.com > content > remote-control...
The 4 digit codes for most programmable universal remote controls for Sharp televisions are: 0039; 0093; 0165; 0386; 1004; 1009; 1011; 1025; 1064; 1077; 1078 ...
You've visited this page 2 times. Last visit: 13/02/23
Necesito ayuda con un tutorial para progamar mi tv Sharp Aquos. Tengo un control universal Laxmax
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
https://www.google.com/search?q=lax-max+universal+remote
Sharp TV Remote codes, use the below codes to control your Sharp TV with a universal remote.
The 3 digit codes for most programmable universal remote controls for Sharp televisions are:
002
013
014
111
502
509
712
812
813
913
918
NOTE: Codes to operate televisions using a Sharp brand universal remote control will be 2 digits long. They will go from 01 to 18.
0039
0093
0165
0386
1004
1009
1011
1025
1064
1077
1078
1081
1097
1099
1153
1157
1274
1298
1311
1312
1362
1375
1378
Sharp tv code
Mustapha, Check the attached links,remote codes,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What are the Sharp television remote control codes
Remote Control Codes For Sharp TVs Codes For Universal Remotes
Codes for Universal Remotes
What is the code for sharp tv?
Hi Ken, the codes are from the link at the bottom of the list...... CHEERS..
002
013
014
111
502
509
712
812
813
913
918
0039
0093
0165
0386
1004
1009
1011
1025
1064
1077
1078
1081
1097
1099
1153
1157
1274
1298
1311
1312
1362
1375
1378
If these codes do not work or you have other codes that work, please leave a comment below.
NEED UNIVERSAL REMOTE CODE FOR SHARP 27F641
Setup codes to Sharp Brand TVs with GE universal remote control are: 0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122.
If you wish to get more codes and other details to many remote controls, check this site. It has details about setup codes and setup proceedings to remote controls. Check them, and find out which brand remote control has codes for Sharp TVs, and buy one according to the availability. Code list and setup proceedings to the remote control will be accompany with it. Never forget to collect it.
Need sharp tv code for ge universal remove
how to enter tv codes for my magnavox tv from my sharp remote
H ow do I program my remote to my tv? I have an RCA universal remote. Model # RCR412S. I lost the user's guide and need to program my new tv to my remote. I have a 42' Sharp tube tv.
The site below helped and gave me the following information:
http://remotefinder.rca.com/default.aspx?site=rca
Code For Model RCR412S
Code 1006 for Sharp TV Code 1012 for Sharp TV Code 1026 for Sharp TV Code 1095 for Sharp TV Code 1111 for Sharp TV Code 1112 for Sharp TV Code 1171 for Sharp TV Code 1173 for Sharp TV
4helpful
I need the code for my sharp tv so i can program my rca remote co
After much searching I finally found the code list for RCR451 Universal Remote. Here are the codes for Sharp TV. 1004, 1007, 1009, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1195
96helpful
10answers
Sharp TV codes
Here are some of the various Sharp TV codes
SHARP 0093, 121, 121, 064, 065, 081, 322, 122, 185
SHARP 002, 013, 014, 111, 502, 712, 812, 813, 913, 918
SHARP 0509, 0913, 0907, 0603, 0002, 0502, 0224, 0228, 0202, 0111, 0813
The 081 code worked with my LC-37SB24U
5helpful
5answers
Lost my manuel "codes" to my rca universal remote control crk74ba3
magnavox codes, 11454, 10054, 10030, 10706, 11990, 11963, 11944, 11931, 11904, 11525, 11365, 11254, 1198, 10802, 13=0386, 10230, 10187, 10186, 10179, 10096, 10036, 11028, 10024, 10020
Top Philips Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
