SOURCE: ImageRunner 1023n is printing vertical bars on page edge
needs a new drum unit most likely if the narrow glass is spotless clean on top. If you print and get a line, then its an internal problem and usually just the drum.
SOURCE: ImageRunner 1023N.. assign IP
Press the additional funktion buton,press the arrow keys until 9 system settings is displayed press ok press the arrow again until 5 neywork settings is displayed press ok.TCP/IP settings will be displayed press ok and change the ip to your network adminatrators specifications.
SOURCE: blank scans- canon imageRunner 1023N
Blank image = transfer/separator unit/corona is not working. Please check the transfer unit.
SOURCE: error msg E197 Cannon imagerunner 1023N
This is a dc controller or image processor pcb communication error, reset all connecters on both boards,if error still their replace DC controller
SOURCE: I have an old Canon 1150 color copier. The bottom
Is there a paper selection wheel or bar in the tray?
Some of the older Canon models have a dial (usually in the lower right hand corner of the tray) or a slider bar (usually on the left hand side of the tray) when you open it. That has to be set properly or the machine has no idea what size paper is there.
