HP OfficeJet K80 All-In-One InkJet Printer Logo
Posted on Dec 19, 2007
Hp K80 printer
Changed the color and black & white cartrigeges. The message now states "remove and check color cartridge" I put in a new 78 color and a new 45 black & white. Fax prints fine but computer will not even print b&w
  • 6 more comments
  • Anonymous Dec 22, 2007
    same problem. no fix yet...brand new printer cardridges
  • Anonymous Jan 27, 2008
    i have the same problem, my printer brings a message that open and check the colour cartrige. please help know what to do.
  • sombi Jan 27, 2008
    i replaced the cartridges but it tells me open and check the cartridges.
  • Anonymous Feb 11, 2008
    I have changed both carts and the error will not go away.
    PLEASE ADVISE ASAP!
  • patsylou Feb 15, 2008
    Same problem. Installed new color cartridge. Message says to remove and check color cartridge. I've done this a zillion times, still have problem. It won't go away. Have tried suggested fixes that don't work for me.
  • rahulbavisi1 Mar 15, 2009
    Hey ! I dont know how to replace the HP officejet k80 cartarage ? can you please suggest how to replace it.
  • Anonymous Mar 12, 2014
    print qualty isuue printer prints only black and white
  • Anonymous Mar 15, 2014
    have downloaded the drivers several times.. still will only recognize black and white and only prints in black and white... advanced settings don't even show color options
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1207
Points
1)Clean cartridge print-heads (GENTLY) with meths or iso propyl alcohol (or cartridge flush solution from ink refillers).
2) clean contacts on side of cartridge with contact cleaner soln (Maplins or Tandy) and a fine brass brush BE GENTLE.
k80 should now recognise and align your cartridges.
K80 is very fussy
J.
Anonymous
Level 1:
  • Posted on Mar 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1207
Points
I have one HP K80 Officejet All-In-One printer. I have just finished printing and after a while the info window became blank while the green power indicator at the point of connection to the printer. The indicator was later coming on and off untill it fially goes off and the printer could not be powered since then. Please help, what's the solution?
A
Anonymous
Have probplem with HPK80.Will not print .Said Wrong color . Same story on Black Cleaned Everything Still not working It Said Initionaling Does Nothing Now it is Aligning Cartage Goes Very slow Mabe HPK*80 is A thash Printer
Anonymous
Level 1:
  • Posted on Jan 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1207
Points
I had the same problem, and it seems to have corrected itself. I too, installed a new "45" black cartridge and got the message to remove and check color cartridge. After I removed it and cleaned it the message stayed on the display for about 5 minutes and then asked me to "align cartriges." After I aligned them I had no problems.
A
Anonymous
I cleaned the vertical centerpost (you'll see it when the cartidge is out)with a small amount of acetone (nail polish remover) on a Qtip & it works fine now....must be some kind of circuit that needs to be closed and the ink on it kept it open....
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
