Box has number 28643 which is also on the bar code 015388 28643. Can I download the booklet for the product?
I couldn’t find a free, official downloadable version of the full instruction pamphlet for the Roshco Baker’s Advantage Pizza Stone (Box # 28643 / Barcode 015388 28643). Many listings for the product mention that a recipe booklet is not included.
WorthPoint
However, here’s what I found and some tips that might help you:
?? What I discovered
Some product descriptions note that the original stone kit did not include a detailed booklet.
WorthPoint
In a legal case involving Roshco, one pamphlet description mentioned standard care instructions (scrape off food with a spatula, rinse in warm water, avoid soap) and that discoloration over time is normal.
Justia Law
+1
There appear to be no currently available PDF manuals or downloadable guides publicly hosted by Roshco.
? What you can do
Contact Roshco / Manufacturer directly
Ask for the booklet by giving them the model number and barcode — they may email you a PDF.
Use general pizza stone care guidelines
Even if you don’t have the exact pamphlet, the standard practices are very similar across brands:
Preheat stone gradually to avoid shock
Scrape off stuck food; don’t use harsh detergents
Let it cool before cleaning
Expect natural staining or darkening over time
Check sellers / reseller sites
Sometimes third-party sellers keep scans or PDFs of older manuals.
If you’re also looking for good deals or techniques to reduce cost, I’ve got a guide on “bringing the price down.” here:
Hope that helps you get your hands on the information you need — good luck!
Question edited for clarity, add magic word.
Question moved from Misc category.
It is just a ceramic stone.
Put it in the oven and heat it up as hot as the oven will go.
Make your pizza.
Take the stone out, sprinkle with ground semolina, and put the pizza on top being careful not to burn yourself.
Put the Pizza in the oven and SET a TIMER.
There is nothing specific to your particular make as it is an As Seen on TV 'sell and run' operation.
How to Use a Pizza Stone for the First Time: An Easy Step ...
The Pizza Heaven
https://thepizzaheaven.com > Tools
Jan 13, 2024 - Place the pizza stone in a cold oven, and turn it on to the highest setting. Then, leave the stone to preheat for at least 45 minutes to 1 hour.
Roshco Baker's Advantage Pizza Baking Stone 13 inch ...
eBay
https://www.ebay.com > itm
Roshco Baker's Advantage Pizza Baking Stone 13 inch pan Used ; Number of Items in Set. one ; Shape. Round ; Accurate description. 4.9 ; Reasonable shipping cost.
US$14.87 · In stock
Missing: instructions ' Show results with: instructions
Pizza Stone- Bakers Advantage By Roshco
OfferUp
https://offerup.com > item > detail
Barely used pizza stone with metal carrying rack, in box. Used only once or twice, in good condition, no cracks/chips, etc. Located near 44th St and Thomas ...
US$5.00
