Garden Logo
ianoloan27 Posted on Nov 10, 2024
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Chain not oiling model RCS514N - Garden
ADMIN Eric
Level 3:
Top Expert:
  • Garden Master 42,220 Answers
  • Posted on Nov 10, 2024
ADMIN Eric
Garden Master
Level 3:
Top Expert:
Answers
42220
Questions
0
Helped
1142262
Points
683303
Clean the oil feeder pipe.
2answers
Lubricate has stopped flowing to lubricate the chain when in use. What should I do?
didnt specify make model ---generic answer--check level in tank ---if good remove cover, chain,and chain bar and look for a small foam sponge type material on inside frame along where chail and bar are thats what allows the oil to lube chain if covered in debris or clogged clean and or replace the following link showes the ioler on different models
Chainsaw Oiler Not Working Yahoo Video Search Results
Jul 12, 2016 • Garden
What chain oil in RM1015P
Hello, The chain lubrication oil is called bar and chain oil. It is specially formulated to cling to the bar and chain to ensure maximum lubrication. You can obtain bar and chain oil at any hardware store or power equipment shop.
1helpful
Describe your sears 18"
I put a new bar and chain on my craftsman 18" chainsaw because the chain keeps coming loose. I am still having the same problem, after running 10 seconds, the chain falls off.
Your response about the electric chain saw that must be oiled manually was about a self-oiling chain saw so it did not answer my question. How to oil the saw? Use an oil can to spread the oild across the...
Your chain saw is a manually oiled model which means YOU have to pump it.YOU do not pour oil on the chain. An auto oiler model works without you doing anything, the pump is run by the engine. A manual model, you pump the oiler The Chain saw has internal oil channels or holes to apply the oil directly under the chain and into the chain bar guide. Pouring oil on the guide or chain will NEVER lubricate the chain properly. Whomever gave you such an idea is just plain wrong. I sent you the link to the owner manual and gave you a diagram. Click here
Jul 15, 2011 • Garden
1helpful
I have a craftsman gas chain saw model 358.352180. It leaks oil from underneath the saw even when not in use.
Make sure you drain the oil when storing your saw. That's because the saw is designed to supply a generous amount of oil to the chain and bar.
Oil leak on Remington electric chain saw model #111174-01
check oil lines and when storing saw stand on end or on side blade up.. vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
2helpful
2answers
What type of oil is used in the remington 16" chain saw?
From page 9 of a M12510US (bar oil is SAE 30 with additives to help it adhere to the bar and chain):
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE #30 motor oil. Note: For temperatures below 30°F, use SAE #10 oil. For temperatures above 75°F, use SAE #40 oil. 3. Replace oil cap at once. Tighten oil cap firmly for good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
Note: It is normal for oil to seep when saw is not in use. Empty oil tank after each use to prevent seepage.
This is one of the most complete "Owners Manuals" Remington offers. If not your saw you can find your manual here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
HTH Lou
1helpful
Stihl model chainsaw chain oiling rate
If correctly set, the chain will throw a light, thin line of oil off of the tip after running a short time. Set a piece of pasteboard at an angle for a target.
Aug 26, 2009 • Garden
5helpful
2answers
Need to know what kind of oil to put in ryobi chainsaw
If it is an electric chainsaw (not gas powered) then the only oil you need is chainsaw bar oil, which lubricates the chain and bar during use (self feeding system). This goes into the chamber at the top of the saw. You can buy chain/bar oil for chainsaws at any good hardware store or outdoor power equipment store. You can use any brand of chain bar oil, most are pretty good.
If it is a gas/petrol operated model, I will need to know the model number to advise on that.
5helpful
Husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Top Garden Experts
ADMIN Andrew
ADMIN Andrew
john h
CJ Rock
CJ Rock
