Radio Communications Logo
ALEX COOLINGS Posted on Apr 19, 2024
How to wire a fridge thermostat
I have a 3 pin thermostat, it has 4 6 and 3 , how do I wire it
Farkhanda Raja
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 19, 2024
Farkhanda Raja
Contributor
Level 1:
Answers
Questions
0
Helped
23
Points
6
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
  1. Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
  2. Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
  3. Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
  4. Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
Top Radio Communications Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Radio Communication Expert? Answer questions, earn points and help others
