Not sure of the legality of the secondary function!
https://www.google.com/search?q=tw-308+taser+flashlight+charger
SOURCE: I need to replace the 120 volt AC wall adaptor
Here is your link to buy it.
http://www.centurytool.net/5140044_04_Charger_W_Small_Jack_p/5140044-04.htm
SOURCE: Schumacher 2/10/50 amp charger,125/225 amp starter
It could be an internal fuse, or that the transformer is malfunctioning.
Before any dis-assembly/internal inspection, be sure that the unit in unplugged.
Good luck...
SOURCE: charger for 12 volts 7 amp battery smf
you need to go to a **** smith store and bye a kit to do this cheers peter
SOURCE: How do you test a
When you insert a battery for charging, which light(s) combination do you see?. There should be red,green and yellow and different individual lights or combinations of lights mean different things. If only the red light goes on, chances are the batteries are to cold to charge. They will not charge below 32F so if your charger is in the garage, take the batteries in the house until they are room temp then try again. If you still have a problem and the unit or batteries are are less than 2 yrs old they should be be under warranty.
SOURCE: need to charge battery not
VERY unusual for a 6 volt system, they just do not work. Count the fill holes, usually there will be 6. Think 2 volts each. To be sure, hook up a volt meter and see, but it just HAS to be 12 volts. Been that way forever.
