2wire 2700HG-B Router (2700HGB) Logo
Posted on Sep 22, 2009
What is 2wire error code 2 - 2wire 2700HG-B Router (2700HGB)
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Sep 24, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
3010
Points
31
When you got this error were you running the installation wizard disc for AT&T?
Because as far as my knowledge with AT&T (Bellsouth) this error code comes out when installing the modem using the Installation Wizard CD, this comes out on a version 3 cd. The error code means
"Failed to Upload to ISP" this possibly could mean that you are not connected to the internet.
Where do i put my activation code
You have to connect to your 2Wire box through a web browser (gateway.2wire.net) And once you're inside the configuration page of the 2Wire, you should see the "key code page" to enter your activation key code.
My At&t 2Wire 3800 BGV-B will connect through the USB Netopia 3D Reach adapter using the 3D Reach Utility and my Sony BR and Cell Phone but, It will not connect through my Win Xp Wireless Zero Conf....
Insert the 2Wire CD and follow the on-screen instructions. If the 2Wire Setup Wizard does not
automatically start:
- Double-click the My Computer icon located on the desktop.
- Double-click the icon that corresponds to your CD-ROM drive.
- Double-click Setup.exe and follow the on-screen instructions.
2. If prompted by the Setup Wizard, enter the 20-digit key code you received from your service provider.
If you were not provided with a key code, contact your service provider.
2answers
Compaq Laptop Windows 7 Acess Point Problem att 2wire
use wired Ethernet, so it works. easy.
wifi is far more complex.
best is to own the router, you have.
then login to it and set it up for wpa./wpa2
wep off.
and a nice password for wifi so others cant hack it. in the hood.
then use those credentials all all your toys. xbox, PCs and cell.
that is the best way
the access point is covered in you manual for the router
there is AP button there, you push.
the PC in question my guess is the drivers are no good.
missing wrong, or corrupted.
no PC full model stated.
no OS stated
no router stated.
so answers will be weak to wrong,.
1helpful
I have a at&t router but changed providers, can i still use it?
YES as long as your service provider authentication with the username and password:
Try this links:
2wire installation guide: http://support.2wire.com/?page=view&article=765
changing wireless settings: http://support.2wire.com/?page=view&article=60
wireless configuration guide for windows XP: http://support.2wire.com/?page=view&article=224
wireless quick reference guide: http://support.2wire.com/?page=view&article=47
this are some articles that may help...
just message me back if you still are encountering some problem - provide some error message as well and any info that may help us configure your 2wire
Can not find my security code for my 2wire
if you can specify what you mean by security code and as to what purpose your using em'
this tips might help you: 2wire wireless network key
The network key is located at the side of the router you will see a barcode on it. It indicated the wireless network key. If you have questions please let me know. Thanks
2 WIRE Activation keys http://www.2wire.com/?p=268
this are the only things i could possibly give you for now..
kindly leave a message if you still have other concerns...
2helpful
2wire 585 forgot password and need 2 config have no phone number to change password
f you don't know the system password for the twowire it has a factory reset button near the lan ports
* Hold down the reset button on the back for 30+ seconds.
* Upon releasing the reset button, the router resets itself to factory settings.
* Connect a computer to the 2700HG-B and browse to the URL http://192.168.1.254/
* Enter a new password, confirm it and enter a password hint at the bottom of the page, in case you forget the password.
* At this stage you might receive a "Page Not Found" error, but the password appears to be set successfully.
* To continue, manually browse to the url http://192.168.1.254
* Home Page (summary)
* Run System Setup Wizard
* Enter key code 5225 2374 WG62 22AS BJ7P (from http://www.2wire.com/?p=268) to set up manual config
-> Next
Choose TIme Zone -> Next
* Enter ISP set up details
* For most UK ISPs this will be
Connection type = PPPoA
VPI = 0
VCI = 38
ATM Encapsulation = VC-Mux
For Be /O2 users only
VPI = 0
VCI = 101
ATM Encapsulation = LLC
Exit Registration when connected to Internet
If this helps you plese rate and vote
2wire problem with ipod touch
So what you're saying is that you don't know what your password is? If so, look at your wireless router, the code may be located at the bottom of the router, perhaps underneath. If not, contact your wireless administrator. Good Luck, karenmaynn
Wireless connection to the 2 Wire modem
Hi
Most of the 2wire gateways have the WEP key or the encryption code on the bottom of it. It would a 10 digit Number of a Five Character one within square brackets.
Other wise you can go to the gateway page by accessing http://192.168.1.1 on another system which is already going online using the gateway or wired to it and in the gateway page under wireless you would find the WEP key incase the default key on the bottom of the 2wire does not work.
Do reply incase this has resolved your issue or you need more help.
Thank you
Rakesh
Expert in Dell Laptop.
Fix this thing before my 20 oz estwing does......
Below are some links you can check out and see if it would help you make the gaming console connect to the net behind a 2wire adsl gateway.
Nintendo Wii behind a firewall/router:
Port Forwarding on a 2wire gateway:
3answers
Psp internet doesn't work.
Try power cycling (turning everything off for about a minute) and connecting again.
Top 2wire Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
