Here are some of the details: Chrysler model number:P68284017AC A Year 2016 Date code:1506 sirius ID audio:073046748611
If your car audio system requires a code to unlock it, there are a few options you can try: Check the user manual: The user manual for your car audio system may contain information on how to unlock it if a code is required. Look for a section on "security" or "anti-theft" features. Contact the manufacturer: If you don't have the user manual or can't find the information you need, you can try contacting the manufacturer of the car audio system. They may be able to provide you with the code or instructions on how to unlock it. Try common codes: Some car audio systems use a default code, such as 0000 or 1234. Try entering these codes to see if they work. Reset the system: If none of the above options work, you may need to reset the car audio system. This will erase any saved settings and data, including the code. The process for resetting the system will vary depending on the make and model of your car and audio system. Check the user manual or contact the manufacturer for instructions.
I think this model will have a Serial Number beginning T00AM*******
If so then the code cannot be calculated but will have to be obtained from someone with access to the official Chrysler database
It will definitely not be available for free from anywhere on the internet.
A reliable supplier can be found here
https://ukbookshelf.co.uk/CHRYSLER.htm
Mention this Forum for a discount
Otherwise try asking your Main Chrysler Dealer
If it is the factory radio, contact your dealer and give the details, the code will be on their database.
