Phil Hayes Posted on Feb 25, 2023
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why doesn't my Philips CDR820 copy a disc when I press "copy cd" then the "yes" button?
zulfiqar ali
Level 2:
Novelist:
  • Expert 84 Answers
  • Posted on Feb 25, 2023
zulfiqar ali
Expert
Level 2:
Novelist:
Answers
84
Questions
Helped
16011
Points
213
If your Philips CDR820 is not copying a disc when you press the "copy cd" button and then the "yes" button, there could be several reasons why this is happening. Here are some possible solutions you can try:
  1. Check the disc: Make sure the disc you are trying to copy is not scratched, dirty, or damaged. If it is, try using a different disc.
  2. Check the blank disc: Make sure the blank disc you are using is compatible with your Philips CDR820. Check the user manual for compatible disc formats.
  3. Clean the laser lens: If the laser lens is dirty, it may not be able to read the disc properly. Use a cleaning disc to clean the lens.
  4. Update the firmware: Check if there is an available firmware update for your Philips CDR820. If there is, download and install it to see if it fixes the issue.
  5. Reset the device: Try resetting the device by unplugging it from the power source for a few minutes, then plugging it back in and trying to copy a disc again.
If none of these solutions work, it may be a hardware issue that requires professional repair. In that case, you may need to contact Philips customer support or a qualified technician for assistance.
Testimonial: "Thank you for your suggestions. I have essentially performed all the steps you recommended. I would like to find someone who might diagnose and hopefully correct the problem. Every technician I've spoken with (includinf Best Buy) say they no longer work on cd players/recorders, and I have been unable to find a valid customer contact for Philips. I would appreciate any contact information."
Top Philips Audio Players & Recorders Experts
SmartAviator
SmartAviator
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
