Heating & Cooling Logo
V
Vijo Jacob Posted on Jun 12, 2022
AC not working properly. Continuously switching om. And off
I have O General AC indoor Model# ASGA24FUTA-AU and outdoor Model# AOGA24FUTA-HU. I was not in home and we have switch off the breaker for somedays and after switching on the breaker.Its is showing error and continuously switching off and switching on. Powerful LED is flickering, Operations LED 3 Times Blinking & Timer LED 5 times blinking.Can anyone help me to resolve this issue
  • Vijo Jacob
    Vijo Jacob Jun 12, 2022
    Thanks for supporting me..
    I turned off due to we were out for some days....
    But once the breaker is on, automatically the the air flow starts in auto mode.. Even i tried to make to cool mode from remote, its is sensing but still continued in automode. And switching on and off automatically..
    From service manual, it is showing Manual auto modr switching error
Jodi
Level 1:
  • Contributor 4 Answers
  • Posted on Jun 12, 2022
Jodi
Contributor
Level 1:
Answers
Questions
0
Helped
287
Points
12
I would start with the basics to trouble shoot. Make sure it has proper air flow and that the coils are clean and free from debree
What I am thinking is since you mentioned turn your breaker off and on was this done to reset the air conditioner or turned off for another reason.
if the breaker was turned off and then back on the compressor would not have time to reset. If you were away and there was a power failure or surge it could have caused this. I would turn the main breaker off but make sure your air isn't set to turn back on when you turn your breaker back on. Give it 30 mins then slowly turn your air on and see if it works.
also you need to make sure if your air conditioner has a drainage tube to drain off the water that, that isn't blocked. As well if your water drains into part of your furnace that hole is narrow to the drainage tube and calcium and lime can build up. Vinegar works great to dissolve the minerals and clear the line. There is a sensor near the bottom of the drainage pain that collects the water to go to the drainage tube. If the sensor gets wet the air conditioner will turn off. If the water stays in the pan or drains slowly the sensor will be triggered continuously and the air will start and stop continuously. It takes a while for the sensor to dry once it has been wet so you might need to leave your air off for a day to let it dry.
Top General Heating & Cooling Experts
Paul Carew
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a General Heating and Cooling Expert? Answer questions, earn points and help others
