Heating & Cooling Logo
Anonymous Posted on Mar 28, 2021
Whirlpool magiccool split AC display showing FC . How do I solve it
Zen Oeuvre
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Mar 28, 2021
Zen Oeuvre
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
4987
Points
14
Double-check on the exact error code. For E2, E4, E5, E6, F1, F2, F3, F4, F5, H3, H4, H5, PL, PH, you must turn on the device And disconnect the power supply, then contact the nearest Whirlpool authorized service center.
You may want to check the full list of Whirlpool AC error codes on this link as well:
https://acerrorcode.com/whirlpool-air-conditioner-troubleshooting.html
4 Related Answers
Anonymous
  • Posted on Jan 11, 2011
SOURCE: Whirlpool Mastermind chrome 1 ton split ac, newly
how to use blower
AJ Ken
  • 73 Answers
  • Posted on Sep 02, 2011
SOURCE: my amcoraire mini split ductless
Support@Pridiom.com
201-266-8234 option 2
steves_here
steve
  • 1692 Answers
  • Posted on Mar 20, 2016
SOURCE: how to solve the problm in my voltas1.5 split AC,showing F7?
Hi this link is an error code manual for air conditioners, Below the link is a copy of F7.. Hope this helps....
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
The fault code = F7
1?Check whether the resistance of sensor is normal, otherwise replace it. 2?Check whether the sensor wire is short circuit or open circuit, and whether the plug is well contacted, whether there is welding off or rosin joint on the electric control board, repair it if there is any above. 3?When the 1 and 2 are both normal, then the components or integrated circuit is damaged, the electric control board should be replaced.
MightyMikeJr
  • 409 Answers
  • Posted on May 03, 2016
SOURCE: how to fix fc error after few seconds of split ac 1.5 ton?
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.
If you need help with your system check out Boca Raton Air Conditioning Service
Top Whirlpool Heating & Cooling Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
