It could be many different items, choke stuck, ignition switch etc. but more importantly have you taken care of your recall? https://www.cpsc.gov/Recalls/2017/Arctic-Cat-Recalls-Snowmobiles
did you notice 2007?? time for new glasses man
it was issued in 2017 for 2007 models. Need my glasses?
20/20 here. if his tank was cracked his nuts would be wet...i had one of those!!
was just making certain. I keep thinking stuck choke...
its a 2 stroke with efi ..could be a bad tether switch, throttle safety switch??
SOURCE: My 2008 arctic cat 400 automatic 4x4 stalled out
It sounds like you have an electrical component shorting out. Water can conduct electricity and cause electrical components to act funny. Look for exposed wires, check for loose or faulty electrical connectors contaminated by water. also check electrical components like your ignition coils, spark plug caps, and relays for damage or faulty seals. You may be able to isolate the problem by spraying the garden hose in specific locations and see if you can duplicate the symptoms. If still no luck, your local ATV dealer may provide advanced component testing with speacial diagnostic tools.
SOURCE: 2007 Arctic Cat LCD Speedometer, gas gage, also 4
did you figure out the problem because mine just did the same thing.
SOURCE: new 2007 arctic cat 400 4x4 13 miles,backed fired now want star
Take the carburetor apart and clean/ inspect it. It is possible that the slow jet was not put in securely, and dropped into the bowl. just reinstall it. You could have a choke plunger that is sticking open.
SOURCE: replace battery on 2007 arctic cat 500 with 84 miles on it. Now
I have Artic Cat 500 it was fine when i parked it about two weeks ago but now it turns over but won't start any solutions
