Microwave Ovens Logo
ira fishkin Posted on Jan 16, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kitchenaid khms2040wbl2. When you start it, the inside light and internal fan comes on, but it doesn't heat and the turntable doesn't turn. I checked the hv diode and fuse and they test ok.
Harjeet s. bola
Level 2:
  • Expert 51 Answers
  • Posted on Apr 02, 2020
Harjeet s. bola
Expert
Level 2:
Answers
51
Questions
Helped
14741
Points
133
Power relay seems stuck,try to replace it or replace the main control board
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Mar 20, 2007
SOURCE: Microwave turns on, but no heat or turntable movement
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure, but it may also be a broken switch mount. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. It is at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 or at http://www3.sears.com
Anonymous
  • 19 Answers
  • Posted on Jan 06, 2008
SOURCE: Ge Spacemaker microwave jvm240 wv Micro hood combo.
sounds to me like the magnatron has shorted out. i don't know of a way to test them unless you have some high dollar equipment. a continuity test prob wont tell you anything. what reading did you get on the cap when you tested it?
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Mar 02, 2008
SOURCE: ge jes1358wk02 microwave...
When a high voltage fails, it shorts. Almost always. I've never seen one open, anyway.
If it's not shorted, it's probably okay.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Anonymous
  • Posted on Jan 01, 2009
SOURCE: Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
David Hanks
  • 178 Answers
  • Posted on Sep 11, 2009
SOURCE: GE Microwave JE2160 does not heat
Does it make any noises that it didn't before it failed?? It could be a bad secondary interlock switch, cook relay on the PCB, HV circuit problem or bad magnetron. You need an ohm meter to troubleshoot. If you take the cover off, you MUST short across the High Voltage Capacitor terminals to discharge any possible residual charge to prevent shock hazard.
Top KitchenAid Microwave Ovens Experts
john h
SmartAviator
SmartAviator
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
