Tablets & eReaders Logo
Posted on Sep 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red light on - Fujitsu Tablets & eReaders
Tony Raia
Level 2:
  • Expert 264 Answers
  • Posted on Sep 16, 2009
Tony Raia
Expert
Level 2:
Answers
264
Questions
0
Helped
52716
Points
672
Not much info to diagnose here. Some laptops use red lights to indicate a bad battery, or wireless is working, or battery is charging, or many other things. What does your manual say about the specific light and what color it should be? Check the manufacturer's website for the manual.
1helpful
When I attempt to charge using USB charger the charging light is red for a couple of seconds and then goes off. I have only just received this case/keyboard. It is obviously not already charged since the...
Turn the keyboard on and let it run all the way down. Then try charging again. If the Red light stays on, the keyboard has was charged. If the same conditions exist, then arrange for a replacement.
2answers
Why is my power light blinking red on my coby tablet?
You won't find a manual. Coby went out of business several months ago. It might be time to replace it. Sorry.
Red x on charging
If its off the mains make sure it is at least 1000mah power output, if its from a computer usb it will only charge while off.
Hkc tablet keeps flashing a red light and won't turn on
His tablet is an HKC they have no volume buttons! Please redo your response!
Blackberry playbook red light flashes but it won 't turn on
this happened to me, it needs charging make sure the lead has the blackberry symbol facing up....
Blackberry tablet wont power on
this happened to me, it needs charging, make sure the blackberry symbol on the lead is facing up, putting it in upside down moves the little tab inside the housing stopping you from charging properly, if it is a bit loose realign the tab with a thin nail file carefully just a touch then push the lead in symbol side up and switch on give it time it should charge..
Either while on or off the docking station the tablet itself no longer seems to illuminate or boot up. The battery also flashes a depleted red. I an assuming with A/C power attached this battery shou
please let me help. the ac adapter will plug into the back of the latop.
check lights then if red light still on after one hour plugged in then you need new battery.try this if two green lights only on after, you do not need battery.
you can sometimes find them on ebay...
hope hlps...let me know
Top Fujitsu Tablets & eReaders Experts
Anonymous
Level 1 Expert
Anonymous
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
