TOC is short for "table of contents". It tells the memory what is on the disc and where...... Does this do this on all cd's?? If so, the disc drive motor is probably at fault. If it's one or two discs, it's probably a scratched or smudge near the center of the disc. CD's play from the inside out.....they start with the TOC.
According to you You don't have use your disk play for a huge time, so that it may damaged or lens became dirty.
You can clear the lens with lens cleaner (clear the optical head).
check the battery was properly charged or working.
Check the disk moved properly.
To prevent the disk erase or damage slide the accidental erase prevention tab.
You can show it to the Technician.
