Sewing Machines Logo
Liz Holt Posted on Jul 20, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When needle not aligned with foot
Movement of needle at base
ADMIN Andrew
Level 3:
Top Expert:
  • Sewing Machines Master 73,781 Answers
  • Posted on Apr 23, 2026
ADMIN Andrew
Level 3:
Top Expert:
Answers
73781
Questions
Helped
6295750
Points
431340
Full 'make model (what it is)' in all questions please, first 3 words. When a sewing machine needle is not aligned with the foot, it often causes needle breaks or poor stitching. Immediate fixes include replacing a potentially bent needle, ensuring the needle is pushed fully into the clamp, resetting the stitch selection to center-position straight stitch, and checking that the presser foot is correctly attached. Facebook +4This video demonstrates how to center a sewing machine needle: 57s
Sewing Machine Repair Doctor
YouTube• Oct 14, 2020
Troubleshooting & Realignment Steps:
  • Check Needle Position Settings: Ensure your machine is not set to a left-needle position (common for zippers) and that the stitch width is set to 0 for a centered needle.
  • Inspect Needle Shank: Ensure the flat side of the needle is facing the correct direction (usually to the back).
  • Check Foot Alignment: If the presser foot itself is angled, lift it, gently twist it into alignment, and lower it onto the needle plate to verify alignment.
  • Reboot Machine: For computerized machines, turning the machine off and back on can sometimes reset the default needle position.
  • Adjust Needle Bar: If the needle bar itself was knocked out of alignment (e.g., hitting a hard object), you may need to adjust the positioning screw found behind the machine's front cover (often a or screw).YouTube +6
Common Causes:
  • Bent needle: The most common cause.
  • Incorrect foot: Using a specialty foot (e.g., 1/4" foot) instead of a standard foot.
  • Wrong settings: Zigzag set with a straight-stitch foot or left-position setting.
  • Knocked alignment: Hitting the presser foot or using heavy fabrics can shift the presser bar or needle bar out of place.Reddit +5
If these steps do not help, let me know:
  • What is the brand and model of your sewing machine?
  • Did this happen suddenly (e.g., after a loud knock/needle break) or gradually?
  • Are you using a specialized presser foot, or the standard one?
Knowing this will help me give you specific instructions on how to adjust your machine.
1 Related Answer
Anonymous
  • 76 Answers
  • Posted on Aug 27, 2009
SOURCE: alignment of needle.
make sure the needle is positioned correctly and all the way up into the deedle slot. lower by hand and check again, if still doing so you can tilt the needly slightly befor tightning the screw. lower by hand again an see
Top Sewing Machines Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Sewing Machine Expert? Answer questions, earn points and help others
